Cannot modify header information - headers already sent
Thread began 1/22/2010 8:42 am by myron364647 | Last modified 2/03/2010 11:11 am by Jason Byrnes | 8533 views | 15 replies |
myron364647
I'm getting a similar problem as another thread, but no resolves helped any. Here's what I'm getting: (username removed with .x.x.)
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/.x.x./public_html/contact.php:1) in /home/.x.x./public_html/contact.php on line 25
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/.x.x./public_html/contact.php:1) in /home/.x.x./public_html/contact.php on line 25
Warning: Cannot modify header information - headers already sent by (output started at /home/.x.x./public_html/contact.php:1) in /home/.x.x./public_html/contact.php on line 34
The code at the top is really basic, just inserting one record from a form on the page to the DB with DataAssist Insert
<?php require_once("Connections/.x.x.DB.php"); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (isset($_POST["Submit"])) // Trigger
$WA_connection = $.x.x.DB;
$WA_table = "contact";
$WA_sessionName = "contact_cint";
$WA_redirectURL = "confirm.php";
$WA_keepQueryString = false;
$WA_indexField = "cint";
$WA_fieldNamesStr = "cname|cemail|ccity|cmessage|cpickedup";
$WA_fieldValuesStr = "".((isset($_POST["name"]))?$_POST["name"]:"") ."" . "|" . "".((isset($_POST["emailaddress"]))?$_POST["emailaddress"]:"") ."" . "|" . "".((isset($_POST["city"]))?$_POST["city"]:"") ."" . "|" . "".((isset($_POST["message"]))?$_POST["message"]:"") ."" . "|" . "".((isset($_POST["cpickedup"]))?$_POST["cpickedup"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_DarkMoonDB;
if ($WA_redirectURL != "") {
Office Guy-172461
See:
Solving the "headers already sent" problem
148/
myron364647
As I have already stated, previous solutions, including this one, is not the problem. There are no spaces...checked and double checked.
the error is saying that the output is at line 1:
This problem can happen if you select the option in Dreamweaver to Include Unicode Signature (BOM) On creating New pages or when saving, it is a PHP bug:
bug.php?id=22108
to fix the problem, Go to File -> Save As. In the Save As Dialogue box, uncheck the Include Unicode Signature (BOM) option.
you should make sure that this option is not set in Dreamweavers preferences as well.
Go to Edit -> Preferences, in the new Document section, uncheck the Include Unicode Signature (BOM) option.
Office Guy-172461
This is also discussed in the link I provided.
Office Guy,
yeah, I saw it there on your page, it is a little bit unclear though. it states that is is a PHP bug, but does not mention the conditions it applies to. To pinpoint it as the cause of the problem, look at the error message:
the important part, is the portion that mentions where the output started:
You identify the cause as being the BOM Bug by the output starting at line 1.
Office Guy-172461
Article has been updated to include this tip.
myron364647
After moving some code around, getting this error. the :1 still exists, and other line numbers have changed some:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/.x.x./public_html/contact.php:1) in /home/.x.x./public_html/contact.php on line 21
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/.x.x./public_html/contact.php:1) in /home/.x.x./public_html/contact.php on line 21
Warning: Cannot modify header information - headers already sent by (output started at /home/.x.x./public_html/contact.php:1) in /home/.x.x./public_html/contact.php on line 30
$WA_connectionDB = $database_.x.x.DB;
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/dm-template-public.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
Should I just recreate the page again from scratch?
can you send a copy of one of the pages you are having this issue with so I can examine the page.
It is possible that the BOM Attribute is being added by the server once the page is uploaded.
myron364647
You'll find contact.zip attached
contact.zip
