Remove checkout.php
Thread began 1/21/2010 9:32 pm by Rich Petersen | Last modified 1/22/2010 5:12 pm by Jason Byrnes | 435 views | 1 replies |
Rich Petersen
Remove checkout.php
Hello,
I do not need to collect billing info, as everything goes though paypal.
So I would like to remove checkout.php
At first instead of having cart.php redirect to checkout.php, I had it redirect to confirm.php and everything on confirm.php still populated correctly. However when I submit the order, my database does not get updated.
When I put back the orignal redirection back to confirm.php, all worked well again.
So obviously I'm mistaken that I can just bypass checkout.php.
Before I look through the code, I figured I'd post up and see if there was a simple solution.
Rich
You will still want to include information about the purchaser when the order Record is created to help identifying the order against who placed it. The store order summary behavior will store the billing info from the checkout page in the order table.I would recommend you keep the checkout page.
