How can I check if a record exists before inserting
Thread begun 5/05/2009 5:40 am by doggyDivemaster | Last modified 6/03/2009 12:12 pm by meister281653 | 16738 views | 25 replies |
doggyDivemaster
I need to check whether a record already exists with the same description as that in a form being submitted for insert by DataAssist and, if it does, don't insert and redirect.
Previously, I could have fudged it by using Dreamweaver's 'Check New Username' behaviour and substituting my description field for the behaviour's username.
I need to use the DataAssist insert record behaviour because I am also using Digital File Pro on the same page but Check New User Name doesn't work with DataAssist's insert record behaviour.
Is their an easy way to check if a record exists prior to insert using WebAssist's tools?
Danilo Celic
One way to do this would be to apply to a test page the built in Dreamweaver Insert Record and the Check New User Name using the same connection/table/column that you want to check in the "real" page. Then copy and paste the code for the Check New Username over to your real page.
This method will likely show a red exclamation mark next to the Check New Username in the Server Behaviors panel due to there not being a built in Dreamweaver Insert Record on the page, but it should work for you as long as you make sure to copy over all of the Check New Username code.
doggyDivemaster
Thanks, I needed to check whether there was a built-in DataAssist behaviour but as there wasn't, I have followed your advice.
Because I was ALSO inserting the filename from a file uploaded by WA DigitalFilePro, I had to modify the Check New User Name code.
Here it is for anyone else reading this post. I have commented out the Dreanweaver lines I had to modify.
' *** Redirect if username exists
'MM_flag = "MM_insert" ***** Removed
'If (CStr(Request(MM_flag)) <> "") Then *****Replaced code with the line below
if (cStr(WA_DFP_UploadObj.Form("Insert.x")) <> "") Then
Dim MM_rsKey
Dim MM_rsKey_cmd
MM_dupKeyRedirect = "index.asp"
'MM_dupKeyUsernameValue = CStr(Request.Form("jobDescription")) *****Replaced code with the line below
MM_dupKeyUsernameValue = cStr(WA_DFP_UploadObj.Form("jobDescription"))
Set MM_rsKey_cmd = Server.CreateObject ("ADODB.Command")
MM_rsKey_cmd.ActiveConnection = MM_printShop_STRING
MM_rsKey_cmd.CommandText = "SELECT jobDescription FROM jobDescriptions WHERE jobDescription = ?"
MM_rsKey_cmd.Prepared = true
MM_rsKey_cmd.Parameters.Append MM_rsKey_cmd.CreateParameter("param1", 200, 1, 50, MM_dupKeyUsernameValue) ' adVarChar
Set MM_rsKey = MM_rsKey_cmd.Execute
If Not MM_rsKey.EOF Or Not MM_rsKey.BOF Then
' the username was found - can not add the requested username
MM_qsChar = "?"
If (InStr(1, MM_dupKeyRedirect, "?") >= 1) Then MM_qsChar = "&"
MM_dupKeyRedirect = MM_dupKeyRedirect & MM_qsChar & "requsername=" & MM_dupKeyUsernameValue
Response.Redirect(MM_dupKeyRedirect)
End If
MM_rsKey.Close
End If
SUGGESTION - You should add this invaluable behaviour to DataAssist
Another option is to create a recordset filtered by the field you want unique and then use validation toolkit to validate the result returns zero records. That is the method I prefer.
meister281653
How does that work?
You create a recordset filtered by the form element, say the email address... then that recordset will set a record count variable. You use that variable in validation toolkit and validate it as a number that is equal to zero. If it isn't zero the validation fails.
This is how it is done in the User Registration Solution and the Powerstore solution if you happen to have them as examples.
meister281653
No I dont have em. I got Validation tool kit, security assist and dataassist.
Hmm, I dont understand that. where do i create the record? in the page of the form?
You create the recordset and add validation on the action page of the form, the same page that has the insert server behavior applied.
Look through the forums, I have walked several people through the process in the past.
paul377172
I've read through the other forums and looked at the run through, but I'm using asp it doesn't help reading the php coding.
I know you create a recordset and filter it by the field you want to use but when you goto server vaildation, what do you choose as your validation type "number" ? then do you choose server variable as total records in the recordset.
Whatever I have tried hasn't worked for me
Your support here would be appreciated.
