How do I putenv
Thread begun 1/08/2010 7:48 am by woodenboat | Last modified 1/15/2010 10:46 am by woodenboat | 2886 views | 5 replies |
woodenboat
How do I putenv
I'll try and explain something I've had very little experience with...
The problem is a godaddy server. Because we are using Gmail for our domain email all the mail that leaves our server is from anonymous@servername.com. I need to be able to force the emails to have an envelop or something like this so the emails are not coming from anonymous@servername.com, but instead from me@domainname.com.
I have changed other forms that are now working using lines like:
'putenv('MAILUSER=mail@address.com');
I'm assuming I can add a line to mail_PHP.php file but I don't know where to put it and how it should be written.
I have waglobal set to: $WAGLOBAL_Email_Server = "" ;
Leaving the godaddy server is not an option right now. Godaddy’s network spam filter bounces all email coming from anonymous.
Help!
in the WA_Globals file set the from address:
$WAGLOBAL_Verification_Email_FROM
to the email address you want displayed:
$WAGLOBAL_Verification_Email_FROM = "me@mydomain.com";
woodenboat
Thanks but I have that setting already.
The problem is the qmail environment puts in anonymous and the email gets bounced.
Like I said > I have fixed this with other php forms by adding something like
$MPForceSender = 'mail@address.com'; or
in the file php file that processes the form.
If/when I find a solution I'll post back unless you can think of something else to try.
Can you send an example script where you have used this so I can see it in context?
woodenboat
problem solved
there were two changes made to make it work on this dedicated godaddy server which uses qmail.
The first was my mistake, I forgot to turn off php safe mode.
The second change was in the in the WA_Globals where I added one line at the top:
putenv ("MAILUSER=noreply@mydomain.com");
woodenboat
hope this helps
if someone else runs into the same issue on a dedicated godaddy server and where the domain email is hosted somewhere else.
