Known issue (and solution) in eCart 4 with Sage Pay/Protx
Thread begun 1/07/2010 12:04 pm by Anna Robinson | Last modified 7/09/2012 10:06 am by Jason Byrnes | 18932 views | 6 replies |
Anna Robinson
There was a bug discovered in eCart 4 for the Sage Pay (Protx) VSP Server payment gateway. If you use this payment gateway and have experienced a checkout failure on the verification page, you will want to download the fix. The fix is provided in all 4 server languages via a file in the Download Center that you can just copy/paste to any of your sites that use this payment gateway.
Log in and visit the Download Center. Click on eCart 4; then click on the Known Issues section. Download the related zip file and follow the instructions in the readme file.
toms016390756
Thanks!
gavin308183
The fix doesn't make any sense...
It says to:
This zip file contains an updated version of the Protx_VSPServer file for all four server languages to fix the issue. Please copy the one for your server langages to the following location in your site:
/WA_eCart/COScripts/
However, there isn't a COScripts folder - just a checkoutScripts folder - and the file in that folder (Protx_VSPForm.asp) doesn't match the one provided (Protx_VSPServer_VB.asp)... copying the replacement file over the original just creates issues.
I'm running the latest version of eCart.
Do you not plan to release a never version of eCart with all this fixed?
this issue is for the Protex VSP Server implementation.
You are using the VSP Form Implementation.
this is why you have a different file name and a different folder structure.
Zion21
Just realized I have been making this same mistake trying to fix a problem for awhile now. Thanks for point this out.
richard435929
3147 : The BillingState field is required
I'm having same SAGEPAY problem with eCart 5 and I'm using VSP Form Implementation.
is there any fix for this version as well?
