PG Resizing Images Displayed in Template/Reducing the # of thumbs
Thread began 1/04/2010 1:09 pm by pnealis225525 | Last modified 1/19/2011 7:49 am by neilo | 4303 views | 35 replies |
pnealis225525
I know this was asked before but after going over the thread I don't see where there was a complete resolution posted.
I am trying to resize both of the large images in ribbon_fullsize_lightbox template and reduce the number of thumbs displayed from 10 to 8. What files and lines of code need to be adjusted?
Could you please shed some light on this for me. Thank you.
The widths that the full size images and thumbnails are created at are set in the admin/common/properties.php file.
There are two arrays created, one for proportional images (mostly used by the large images):
$GLOBALS['resize_proportional'] = array(
    array('w' => 1024, 'h' => 768, 'watermark' => true),
    array('w' => 782, 'h' => 481, 'watermark' => true),
    array('w' => 163, 'h' => 92)
another for cropped images (mostly used by the thumbnails):
$GLOBALS['resize_cropped'] = array(
    array('w' => 62, 'h' => 62),
    array('w' => 132, 'h' => 140),
    array('w' => 102, 'h' => 102),
    array('w' => 42, 'h' => 42),
    array('w' => 782, 'h' => 481)
when you process the images to upload them, they are crated at the sizes in both arrays.
So to add 680 x 420 images for both thumb and large image, you would need to modify both arrays:
    array('w' => 163, 'h' => 92),
        array('w' => 680, 'h' => 420, 'watermark' => true)
    array('w' => 782, 'h' => 481),
        array('w' => 680, 'h' => 420)
Then, in the index.php file in the gallery directory you are using. On about line 14, there should be some code like this: &thumb=62c&full=782p.
"&thumb=62c" is telling it to use "array('w' => 62, 'h' => 62)," from the resize_cropped array for the thumbnail. "&full=782p" is telling it to use "array('w' => 782, 'h' => 481, 'watermark' => true)," from the resize_proportional array for the large images. to change that so the large image uses the 680 x 420 image we added:
&thumb=62c&full=680p.
the following how to has instructions for changing the number of images that are displayed in the ribbon:
powergallery_custom_gallery_ht.pdf
pnealis225525
Thanks allot for the help, Jason. I will give this a whirl!
you're welcome.
Lee Firth
It would be good if this solution was added to the "How To" section of the PowerGallery support and training.
I will pass this along to our documetation team.
Please use the feed back form:
submit-idea.php
and select Documentation to submit ideas directly to the documentation team.
pnealis225525
OK, Jason. Sorry this took so long to get back to you. Once you change the code per your instructions I assume you have to re-upload the images in orfer for them to be resized properly.
I would also like to find out where in the code can you eliminate some of the templates and replace one or say two with my own like the pan and zoom one I showed you some time ago.
main.html
Coupled with this I assume there is a way to create and store only the image sizes you use rather than all generated by the properties.php.
Thanks in advance, Jason.
Justin Nemeth
You'll need to re-process the image yes. However, a quick way to do it is to update the image watermark. This will re-size all the images without you actually having to re-upload them all.
All the front end designs are in the galleries folder. If you remove a gallery from there, it won't show up in the admin. If you add a new one, it will show up in the admin. Each gallery has a unique admin/design.xml which controls the name and description that shows up in the admin. For each css style (i.e. dark, light), there is a dark.png and light.png that are the thumbnails in the admin.
The properties.php file contains all the sizes, so just like adding the lines of code will create the new sizes, removing the lines you don't want will not create those sizes. I would recommend keeping all the default sizes though since all the built in galleries and admin need all those sizes to work properly.
-justin
pnealis225525
Thanks, Justin. That is very helpful!
elevy388997Beta Tester
I know this is an old topic but I went to the index.php file to change the '&thumb=62c&full=782p' on line 14 to '&thumb=132c&full=782p' . This should change the thumbnail size to 132 x 140 as indicated by the admin/common/properties.php... correct? I also "updated" my watermark, and it is still 62 x 62.
specialevents.html
