styles in editor
Thread began 12/29/2009 5:56 pm by dave276887 | Last modified 1/26/2010 6:52 pm by Dani Chankhour | 1236 views | 9 replies |
dave276887
styles in editor
Hi
is it possible to link to a style sheet for the page editor so when you use the styles drop down the styles that you are using for the site appear there??
cheers from Dave Downunder
Dani Chankhour
Yes, but to make that change, you will need to edit the HTML Editor instance, do you own HTML Editor?
reneas.email303886
Style Sheet Linking
I am using PowerCMS I also have HTML Editor. I want the client to be able to use the styles defined in my style.css file. What do I need to do to achieve this?? Do I need to replace a css file on the server with my css?? I found this entry in the fck editorarea.css file:
* A user can configure the editor to use another CSS file. Just change
* the value of the FCKConfig.EditorAreaCSS key in the configuration
* file.
Please explain in detail what file contains the FCKConfig.EditorAreaCSS key...thanks!
Renea
Dani Chankhour
To add the styles in your style.css, reenter the HTMLEditor (Let me know if you have any questions about doing that) and click the customize button, and then click on the Styling tab, and browse to your style.css file. You can then select the classes that you want to show in your Styles drop down.
jcav26033
I have questions about "Entering the HTMLEditor."
Hi Dani,
In a later message you give instruction on what to do to customize the HTMLEditor in Power CMS. I am on MacOS (Snow Leopard) and using Dreamweaver CS3. I do not understand what you mean by "entering the editor from the properties window." How do you do this from within Dreamweaver?
Is there just a simple config file that one can hand alter with a text editor?
Thanks!
Dani Chankhour
When i said "reenter the HTML Editor", i meant with HTML Editor you are able to go back to the wizard and make changes to the Editor. to do that:
1. in Dreamweaver open the Properties window (Window -> Properties)
2. In Dreamweaver Design View, click on the HTMLEditor
3. in the Property window you should see an edit button, click the edit button and that should launch the HTML Editor wizard.
once the html editor wizard is open click the customize button and then the style tab and then select the css file you want to use in the editor.
neilo
Hi Dani
Which file stores this info please (so I know which one to upload?)
neilo
Ah it's OK, I found it.
(HTMLEditor/custom/contents_insert_ContentValueStyles1.xml) in the Root Directory.
I will need to copy that to the HTMLEditor/custom/contents_insert_ContentValueStyles1.xml file in my CMS folder.
info360637
?? Don't understand
On which file should I be working? This is very poorly covered - surely it should be a basic requirement if Power CMS is designed to fully integrate with an existing site?
Could someone walk me through the process - I can't even find an explanation of what the 'html editor' is?
Thanks!
Jim
Dani Chankhour
To make these updates you will need to be on the contents_insert.php page or the contents_update.php page.
The HTML Editor is where you type the content that shows on your pages.(html-editor/)
You will need to have HTMLEditor installed to make the updates to include the different style sheets.
