add links to cation
Thread begun 12/17/2009 5:59 am by gruant2000381341 | Last modified 1/18/2010 2:29 pm by Awemaker | 2531 views | 4 replies |
gruant2000381341
add links to cation
Is there a way to add hyperlinks to the image caption
Justin Nemeth
You can put in HTML code in the title and description fields. So just put your <a> tag and it should render fine.
-justin
Awemaker
Which CSS to modify text link color?
Gee, this works like a charm! I was even able to use a small image link in the title.
Now, I just want the to change the text link color so that I can see it a little better in the Dark Galleries. Which CSS menu handles that?
Justin Nemeth
All colors are defined in the galleries/<your gallery>/css/dark.css file. That should do what you want.
-justin
Awemaker
Well, I did it differently, but I got it!
I freely admit I am still a nimrod on CSS- having said that. . .
I wasn't quite sure how to add it there, or if I should have added it in the common.css which is, well, common to the light and dark themes. Also, the (what I guess are) naming conventions scared me away to look elsewhere. So I did, and. . .
I found out that the link colors were being defined all the way up in the screen.css from having used CSS Sculptor, and so I changed it there. It was something I hadn't tweaked yet, and the colors I chose for links work site-wide as well. So that's another one crossed off the list.
Thanks for your help!
