No Delete or Update transactions on page...
Thread began 3/06/2009 12:15 am by garry.wilmeth268291 | Last modified 5/15/2009 4:06 pm by mkondakow248259 | 1929 views | 13 replies |
garry.wilmeth268291
I am trying to apply the digital file pro delete option to the delete page created by DataAssist and I get the following message:
"There are no delete or update transactions on the page. Please insert appropriate transaction first"
In server behaviors, there is a "Delete Record" items. What am I missing here?
It sounds like you are applying the ADDT version of delete file on a DataAssist page. That is not our error message.
vera155296
I am getting the same message although the delete record behaviour has been applied using Data assist, and I am definitely using the Webassist Digital File Pro server behaviour. I do however have ADDT installed, so could there be a conflict in the extensions?
I am currently disabling it, although I do not want to keep having to do this every time I use your extension as it is a lengthy proccess, so if you have a workaround it would really be appreciated.
I am using CS4 on Windows Vista. Thanks in advance for your help and/or guidance.
What version of DataAssist do you have. If they use the exact same name for a server behavior, then it could cause the problem of their server behavior opening when ours is selected from the menu. I thought we had resolved this in a previous build but it is possible there are still conflicts we were not aware of.
vera155296
Thanks for responding so quickly. I am using the latest available version 2.0.4. It works OK now I have uninstalled ADDT (using version 1.0.1)
I will note that we should rename the server behavior in the next release because of naming conflicts with ADDT.
vera155296
Thanks Ray, is there a timescale for the next release?
Not publicly. This is one of the products we are planning on updating sometime this year, but the schedule and feature set is still in discussion.
mkondakow248259
DFP2 conflict with ADDT
I guess the programmers at Webassist forgot to rename the server behavior name because of conflicts with ADDT's name in the release of DFP2
Do you know if this still on th eagenda?
Mickey
I think once Adobe announced ADDT was being discontinued, the issues related to incompatability went to the back burner.
If you want to fix the problem, you can probably do it yourself... just go to the user configuration folder: Configuration/Severbehaviors/php_mySQL/DigitalFilePro/Delete File.htm
and rename it to something like: Delete Files.htm
Then go to the file in the same folder: Delete File.edml
Open it in notepad and update the reference to Delete File.htm and update it to the new file name.
That should eliminate the conflict. Let me know if you have any problems.
