Change product order
Thread began 11/17/2009 1:11 am by mousework50137 | Last modified 8/01/2010 10:19 pm by downloads336743 | 3173 views | 11 replies |
mousework50137
How do I modify the recordset on my product page so the most recently added product is displayed first.
Currently the SQL in the recordset reads
SELECT *, (ProductStock - (SELECT Coalesce(Sum(DetailQuantity),0)
FROM orderdetails INNER JOIN orders ON OrderID = DetailOrderID
WHERE DetailProductID = ProductID AND OrderDate > ProductUpdateDate)) AS NumLeft FROM products LEFT OUTER JOIN productcategories ON ProductCategoryID = CategoryID WHERE ProductLive <> 0
Cheers
Add:
ORDER BY ProductUpdateDate DESC
to the end of the query:
larsentim278054
Is there a way to order it by Product price? (most expensive on top)
change the order by clause to use the product price column:
ORDER BY ProductPrice DESC
larsentim278054
Thank you for the quick support! I'll give that a try.
larsentim278054
That worked perfectly. Thanks!
I don't suppose there's a way to add some buttons on the top of the product results page, letting the user sort it themselves? Like a "alphabetical, or newest, or by price" type thing?
see the DataAssist "Sorting by column links" tutorial in the solution recipe section of the DataAssist support page:
dataassist/
larsentim278054
Ah - okay I'll check it out. Thanks Jason.
You wouldn't be able to check my thread over here, would you? showthread.php?t=7503&page=2
I've already responded to your other thread.
downloads336743
I've read through the above and looked at the DA guide, however, i have a client who had a site built a while ago and it's now a little bit difficult to redo the database info to update the order of how the information is sorted (they want it done Music Name alphabetically). I was wondering therefore, if there is a way to just update the code rather than go through the recordset panels etc...I noticed a way to do it for PowerStore but not for DA
Currently the code for the layout is
<table class="WADAResultsTable" border="0" cellpadding="0" cellspacing="0">
<tr>
<th class="WADAResultsTableHeader">Item ID:</th>
<th class="WADAResultsTableHeader">Music Name:</th>
<th class="WADAResultsTableHeader">Music Description:</th>
<th class="WADAResultsTableHeader">Music Type:</th>
<th>&nbsp;</th>
</tr>
<?php do { ?>
<tr class="<?php echo $WARRT_AltClass1->getClass(true); ?>">
<td class="WADAResultsTableCell" style="width:60px;"><?php echo($row_WADAmusicuploads['ItemID']); ?></td>
<td class="WADAResultsTableCell" style="width:155px;"><a href="musicuploads_Detail.php?ItemID=<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" ><?php echo($row_WADAmusicuploads['ItemName']); ?></a></td>
<td class="WADAResultsTableCell" style="width:150px;"><?php echo($row_WADAmusicuploads['ItemDescription']); ?></td>
<td class="WADAResultsTableCell" style="width:150px;"><?php echo($row_WADAmusicuploads['ItemType']); ?></td>
<td class="WADAResultsEditButtons" nowrap="nowrap"><table class="WADAEditButton_Table">
<tr>
<td><a href="musicuploads_Detail.php?ItemID=<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" title="View"><img border="0" name="View<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" id="View<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" alt="View" src="../../WA_DataAssist/images/Slate/Traditional_zoom.gif" /></a></td>
<td><a href="musicuploads_Update.php?ItemID=<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" title="Update"><img border="0" name="Update<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" id="Update<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" alt="Update" src="../../WA_DataAssist/images/Slate/Traditional_edit.gif" /></a></td>
<td><a href="musicuploads_Delete.php?ItemID=<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" title="Delete"><img border="0" name="Delete<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" id="Delete<?php echo(rawurlencode($row_WADAmusicuploads['ItemID'])); ?>" alt="Delete" src="../../WA_DataAssist/images/Slate/Traditional_trash.gif" /></a></td>
</tr>
</table></td>
</tr>
<?php } while ($row_WADAmusicuploads = mysql_fetch_assoc($WADAmusicuploads)); ?>
</table>
Thanks for any help!
