Coupons - Exclude certain products?
Thread began 11/15/2009 12:49 pm by psychobilly1165508 | Last modified 11/25/2009 9:44 am by Jason Byrnes | 8112 views | 47 replies |
psychobilly1165508
I need to have a coupon code that will exclude about 4 products in my database.
How can accomplish this? Using ASP/VB + MS SQL server.
Create a new column in the cart, for examples sake, lets call it "discounted". For items that the discount can apply to, set the value in the add to cart button for the discounted column to 1. for items it does not apply to set the value to 0.
When creating the discount rule, add the following trigger:
AND
Number of Item With a Specific Column Value:
Number of items where [discountable] has a value 0f [1] is [>] a value of [0]
for the calculation, use:
based on Items with a specific Value:
Total Of [Totalprice] where [discountable] has a value 0f [1] [times] [0.1]
for a 10 percent discount.
larsentim278054
I'm confused. How do you setup the add to cart button for particular items differently than others? I mean, if you aren't setting up these pages manually? I guess, what I'm asking is, how do you assign an item a column value (the column you setup in eCart)?
I'm trying to apply a "Free shipping" promotion to only a certain brand of products. I tried doing the free shipping discount, and included the items in the trigger, but it then discounts the entire shipping amount, including items that were in the cart, that are not of that brand. So I need to figure out a way around that - and I think what you describe here is what I need, but don't know how to assign the items with the value I choose.
Thanks!
I dont understand what you mean by:
"if you aren't setting up these pages manually"
is the product information coming from a recordset?
if that is the case, then you need to also create a corresponding column in your products table. In the database you will apply the value to that DB column. In the Add to cart button, bind the new cart column to the Database column.
larsentim278054
Ahh.. Yes, that was the step I was missing. Okay, I understand now. Yes, the product is coming from a recordset. It's from PowerStore's product_results.php page. This is something I can do with that, right? Or because it's utilizing the search function to show the products, is this going to be more complicated...
So I add a column using phpMyAdmin to the Products table. Should I add a default value of zero?
After I do that, I goto the products that I want free shipping applied to, and in that new column, I add a # 1 to those item's. Then in the products_results.php page -> in the add to cart button, I bind that new column to the new column I created in the cart. This is the part I don't understand how to do, but I'm guessing that I'll figure it out.
Although I just read your other reply stating that eCart would need to support two shipping rate lookup behaviors, so is all this pointless? Is it really impossible to offer free shipping on certain products? Or were you stating that, in regards to the initial way I was trying to get this done. Adding the new column to the products table - will this method get around needing two shipping rate lookup behaviors, or will it just get me so far and I'll run into the same problem....
my comment about two shipping rate lookup behaviors was to address wanting to show how much is being saved.
if you want to show how much the shipping would have been without applying free shipping to some of them, you have to use two shipping behaviors. One to lookup the total, one to lookup the discount.
I thought this thread was about applying the discount to certain items? This will not be affected by shipping unless I am missing something.
larsentim278054
I guess I assumed that applying a discount to certain items would be similar to applying free shipping to only certain items. Am I mistaken? Is this impossible? Or are your instructions not going to work for discounting the shipping costs for certain items. I guess it doesn't matter whether to show how much the shipping cost they are saving, although that would be nice. But as long as it discounts shipping on only those certain items and not on items that aren't free shipping, that would suffice. Would this not accomplish this?
Yes, you can use the same method for free shipping.
Create a db column for shippable.
set it to 1 for products the shipping should apply to and 0 for products it should not apply to
create a cart column for shippable
bind the cart column and the DB column in the add to cart button.
it will get a little different here though,
In the eCart object, create a new calculation called shipWeight set the calculation to:
(([shippable] == '1')?[Weight]:0) * [Quantity]
Then on the confirm page for power store, find the followng code:
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".WA_eCart_FormatNumber($WA_Store_Cart->TotalColumn('TotalWeight'), true, 1)  ."";
and change it to:
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".WA_eCart_FormatNumber($WA_Store_Cart->TotalColumn('shipWeight'), true, 1)  ."";
larsentim278054
Ah - thank you so much for this. I know I didn't explain it very well. Thanks! I'll let you know how it works out.
You're welcome.
