Flash Banner won't play in Firefox
Thread begun 11/13/2009 10:19 am by mrobben375515 | Last modified 11/25/2009 12:02 pm by Jason Byrnes | 5448 views | 10 replies |
mrobben375515
I inserted a flash banner into my php document (web assist power store template) using dreamweaver under insert>media>flash and it plays in safari and IE but shows up blank in Firefox. The link to the site is funphotobooks.com ...please help. thanks
It appears there is a bug in your Scripts/swfobject_modified.js script.
If I change:
function setVisibility(id, isVisible) {
var v = isVisible ? "visible" : "hidden";
if (isDomLoaded) {
getElementById(id).style.visibility = v;
else {
createCSS("#" + id, "visibility:" + v);
to:
var v = isVisible ? "visible" : "visible";
if (isDomLoaded) {
else {
I can get the banner to load.
mrobben375515
flash
I changed the code and it still doesn't work on the computers I've tried...any other suggestions?
When i view source of the js file, it is still using the old syntax:
the change does not appear to be uploaded.
mrobben375515
flash
I uploaded it correctly this time and still doesn't work as far as I can tell. see if it works for you...other possibilities?
It looks like there is a problem in the flash swf file itself. The swf file is being loaded, that is what is producing the blue background, but the carousel images are not loading, Have you tried adding the flash object to a plain page to get it working in FireFox? if you can get it working in a plain page, we could debug what the difference is, but it looks like an issue with linking the images within the flash file.
neilo
Odd - I can see the swf in firefox by directly accessing it at
carousel.swf
- but not on the actual page that references it. I'm using Firefox 3.5.5 on Vista SP3
mrobben375515
flash
I can get it to run in firefox in a plain html page...the link is carousel.html ....so maybe the problem is the code in the php doc?
The code for adding the object to the page and the javascript code on this page is very different from what is on the other page.
try using the code from this page on your index page.
mrobben375515
flash
it doesn't work at all when i take the code generated by flash's html and paste it into the template. I really don't understand why it works in safari and IE but just not Firefox...
