using both iRite and HTML Editor extensions
Thread begun 11/11/2009 12:23 pm by web_assist_mail157665 | Last modified 11/12/2009 12:17 pm by Dani Chankhour | 2346 views | 3 replies |
I have sites with iRite that I may have to edit
at the same time, I may purchase HTML editor for new sites
I trust the two are separate independent extensions?
tia
Dani Chankhour
NO, You can't install iRite and HTML editor at the same time. But you should be able to make edits to iRite instances using HTML editor.
Originally Said By: Dani Chankhour
Is that should - as in maybe it will work - or definitely it will work
tia
Dani Chankhour
It definitely should work. But it is recommended to delete your iRite instance and add a new HTML editor instance since you are able to save the HTML Editor as a preset.
