Update Page
Thread begun 11/08/2009 9:02 am by eric284736 | Last modified 11/20/2009 11:24 am by Eric Mittman | 6498 views | 13 replies |
eric284736
Update Page
Using the HTML editor (Irite) on the update page causes an error if the field is left blank when the initial record is added. I was told to change the database field to input a blank string value.
How do I do that working directly on the SQL panel - see the attachement screen shot.
thx
Eric
You should be able to put in an empty value here, like a space or "". If you do not need this field in your db to be required you should just update the table to make it not required. Any required field in your db should have a value when a record is inserted. If the value is not needed for every record on insert then it should not be a required value unless you have some alternate content that you would like to add to it.
eric284736
Thanks Eric!
Your welcome, did you add in the blank space or did you just take off the required?
eric284736
Hi Eric,
I have tried a couple of things with no success.
In SQL I added the default value as N' '. But the field is set to accept Nulls.
That does not work, so the did N'.' and that does not work.
The error I get on the update page if the field does not contain anything is:
Microsoft VBScript runtime error '800a005e'
Invalid use of Null: 'CStr'
/cmi/property-update.asp, line 173
On the insert page, the field is NOT required and it is NOT required in the database because an entry might be added and the additional information field might not be available at the time that uses the IRite editor.
Does that make sense?
thx
Eric
You should be able to have the field be not required and leave a value blank when inserting. It should just make it an empty value. I did a test with my own pages and can only get this error to occur if I replace the value referenced in the Cstr to be Null. Can you post back with a copy of the page in a zip archive so that I can take a look and try some things out?
eric284736
Hi Eric,
Here is a copy of the update page and the insert page.
Eric
The error that you are getting on this update page is referencing line 173 which is where you have the iRite instance. The cStr function is being used around the value from your db like this:
cStr((rsPropertyTable.Fields.Item("Content").Value))
This tells me that the value inside of this cStr is equating to Null. You should try assigning this value to a variable, then do a check for null, if it is then set the value to be "". You can use the IsNull function for asp, it looks like this:
IsNull()
returns true or false based on the value of the parameter
Dim theVal = rsPropertyTable.Fields.Item("Content").Value
If IsNull(theVal) Then
theVal = ""
End If
Then just use this variable for the value of your editor on the page.
eric284736
Hi Eric,
Sorry to be dense. Do I alter the code like this:
Original Code:
' WebAssist iRite: Rich Text Editor for Dreamweaver
Dim WARichTextEditor_1 : Set WARichTextEditor_1 = CreateRichTextEditor ("Content", "../WA_iRite/", "800px", "800px", "Custom", "../custom/property-update_Content2.js", "" & cStr((rsPropertyTable.Fields.Item("Content").Value)) & "")
Updated:
theVal = ""
End If
That is mostly how you should update it. You will need to replace the rs code for the instance with the variable and end the if a little earlier like this:
theVal = ""
End If
Dim WARichTextEditor_1 : Set WARichTextEditor_1 = CreateRichTextEditor ("Content", "../WA_iRite/", "800px", "800px", "Custom", "../custom/property-update_Content2.js", "" & cStr((theVal)) & "")
