"Object doesn't support this property or method" error
Thread begun 11/05/2009 8:20 am by Nathon Jones Web Design | Last modified 11/19/2009 12:46 pm by Jason Byrnes | 8299 views | 5 replies |
For some reason, I'm now getting the following error on my maps page where it used to work:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 1.1.4322; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Thu, 5 Nov 2009 16:18:10 UTC
Message: 'x' is null or not an object
Line: 1163
Char: 56
Code: 0
URI: main.js
On the same page, I'm also getting the following error:
Message: Object doesn't support this property or method
Line: 12
Char: 1
Code: 0
URI: %7Bmod_drag,mod_ctrapi,mod_zoom,mod_ovrmpc,mod_api_gc,mod_apiiw%7D.js
Here's a link to the offending page:
scottish-music-event.asp?e=891&b=1
I'm using DW8.0.2, Win XP Pro, IE8 and Pro Maps for Google version 1.0.5.
Hope someone can help. Thanks.
Regards
Nathon
The error is occurring because you cometed out the following line:
// icon_0.infoWindowAnchor = new GPoint(8,3);
un-comment that line, and the error will go away.
removing the WindowAnchor
Thanks Jason.
What if I don't want the WindowAnchor though? I really don't want the "speech bubble" thing on the map and was advised that I could comment that out.
How do I prevent that from displaying, without commenting out that line and without causing "error on page" errors?
Much appreciated.
Regards
Nathon
comment the code that loads the info window.
To keep if from opening on initial load, do search for all occurance of:
marker_0_0.openInfoWindowHtml
It will be in a few places,Whether to comment it or not depends on the surrounding code. It will either look like:
if('address_0_0' == 'address_0_0')
marker_0_0.openInfoWindowHtml(address_0_0.infowindowtext);
or:
GEvent.addListener(marker_0_0, 'click', function() {
to make it not load the bubble on initial load, comment it if it looks like the first example:
//if('address_0_0' == 'address_0_0')
//marker_0_0.openInfoWindowHtml(address_0_0.infowindowtext);
This will still allow the bubble to load if the marker is clicked. if you do not want that to happen as well, comment the second example too:
//GEvent.addListener(marker_0_0, 'click', function() {
ta.
Perfect. Thank you Jason.
If I upgrade my version of Pro Maps for Google, will it overwrite my commented out lines?
Only if you edit the map.
