Inconsistent sub-menu background widths
Thread begun 4/21/2009 5:39 pm by jeremyandrebecca67370 | Last modified 4/22/2009 11:26 am by jeremyandrebecca67370 | 3567 views | 4 replies |
OK, I have an issue with sub-menu background widths that are not consistent across browsers.
I set up a slimmed-down file to better illustrate the problem:
menutest.php
Issue #1:
For some reason, in Internet Explorer 7, the sub-menu background widths stop at the end of each text link. This is, of course, not the way it should appear.
However, in Firefox 3, the widths are all the same for each item in a particular sub-menu list, all based on the length of the text in the longest text link.
(It's even stranger in Firefox 2 for the Mac - some items appear correctly: about, news, music, & store) while others have the problem I describe here for IE (media & connect) But, that's another story!)
Issue #2:
Now, while the widths function correctly in Firefox, there also seems to be another issue that keeps things from being consistent.
Notice that I've had to put a 10px pad on the right side so that the CSS Menu Writer display, as well as Internet Explorer, will give a little room to the right of the text link. No such padding is necessary for the left side. It seems to do that correctly by default. (I'm not sure if it has anything to do with the inside/outside bullet specification or not.)
Anyway, the menu would look perfect in Firefox if it was not for the extra 10px pad I had to add. Because of it, I end up with twice the amount of padding I actually want in Firefox, even though it produces the pad I'd like to see for Internet Explorer.
Of the two issues, though, I really want to fix the background width of the sub-menus (issue #1). If the padding issue (#2) can't be resolved, I could live with that. But, maybe someone knows a way to fix both.
Thanks so much, in advance, for the help.
Jeremy
It is because you are using width:100% and IE simply treats that differently than other browsers.
The menu writer really has a requirement to use fixed width submenus by defining the exact width.
If you won't have another menu level under it, you may have some workarounds that could work for you.
One thing you can try is simply remove the width attribute entirely instead of using width:100%
if that doesn't work you might be able to change the LI tag to display:block
If neither works, I would suggest defining an exact width. This is the only solution that would allow another level of menus, since it needs to know the width of the first level to position the second level properly.
Thanks again for the reply!
Well, setting the width to 100% was what I had resorted to because leaving it blank wasn't working either. And, unfortunately, using "display:block" didn't work either. (Internet Explorer is so weird!) Firefox seemed to do fine with just about anything I'd throw at it though.
So, I had to go with defining an exact width. Not exactly ideal since it applies to all sub-menus, and because I'm using variable generated sub-menu link text. (It just would have been nice to have the widths adjust automatically when changes are made to the links.) But, this will have to do for now. And, it is certainly better than having the varying widths.
Hopefully Internet Explorer will catch up in terms of brain-power, or standards compliance, or something. Such a pain to always have to accommodate it.
Thanks again for the assistance!
All the best,
Jeremy
You could always go in and hand edit the widths for each individual submenu, but this isn't possible through the interface mostly because of the increased difficulty in positioning the next level of menus.
Good point!
And I guess I could even set it up in my site management area to specify a certain width value along with my new link text, just in case I want to deviate from my default setting.
Thanks for the idea!
Jeremy
