Contact form Solution Pack
Thread begun 11/03/2009 10:26 pm by julie777375638 | Last modified 11/04/2009 10:21 am by Jason Byrnes | 1501 views | 1 replies |
julie777375638
I have just purchased the contact form solution Pack and I am trying to test it on the hosting server. I get the error HTTP 500 the website cannot display the page for the contact.php code. and the following....
Most likely causes:
The website is under maintenance.
The website has a programming error.
What you can try:
Refresh the page.
Go back to the previous page.
More information
This error (HTTP 500 Internal Server Error) means that the website you are visiting had a server problem which prevented the webpage from displaying.
I have not changed the code provided by the package, so the contact.php is as in the package. The thankyou.php works fine. Any suggestions??
Many thanks
Julie Thompson
This is a very generic message, are you using IE? Try using FireFox instead, this may show the real error that is occurring.
If not, try adding the following at line 1 of the contactus.php page:
error_reporting
(E_ALL);
if this still does not show the error that is occurring, you will need to contact your hosting company to ask them to look into the error logs. Once we know the actual error we can begin to trouble shoot the problem.
