DataAssist Root Directory
Thread begun 11/02/2009 3:46 am by rob108609 | Last modified 11/03/2009 12:53 am by rob108609 | 3336 views | 6 replies |
rob108609
I am currently using DataAssist 2 to create administration areas for ASP websites using an Access database.
My Windows hosting is setup with the following folders in the root directory:
Connections (Database connections)
db (Database folder)
wwwroot (all public files)
DataAssist always puts the WA_DataAssist file folder in the root of the Dreamweaver site, which doesn't have public access. After creating pages I then have to move this folder and update all pages manually to make sure changes have taken affect.
Is there anyway to specify where DataAssist places this folder?
neilo
The root folder is the default location for the WA_DataAssist folder, and it is probably best to leave it there, those are just the files that your created pages (results, update, detail etc.) refer to. You can specify where the created DataAssist pages go - i.e. a secured folder in an admin area - when you run the DataAssist Wizard.
rob108609
Thank you
Yes, I've been putting the created pages into other folders during the wizard stage.
But I didn't know if I could change the default location for the 'include files' folder. At the moment, if I wanted to leave the DataAssist folder outside the wwwroot folder, I have to contact the host and get them to change the permissions on the folder. Which is a bit of a pain when you are administering a lot of sites.
I can move the folder into the wwwroot folder and update the files, but everytime I go back into the wizard, it overwrites the changes and recreates the original folder.
Some extensions also show an error in the bindings panel if the folder isn't in the default location.
But thanks for your reply...
neilo
Ah - sorry, I didn't read your first post properly. I think I now see what you mean.
When you go to:
Site > manage sites > (select your site) > Edit > Remote info:
Have you set the 'Host directory' to the proper setting? The Host directory setting should have been provided by your hosting provider with your login and FTP details, see attached pic for example of mine.
What have you got for yours? I suspect it should be something like 'wwwroot/' or /wwwroot/yoursite.com/ or somesuch.
I think the correct setting here would solve your problem.
rob108609
Thank you again
Yes, that's all sorted correctly. It's the actual extension default that I want to change. I need to have both the FTP and Dreamweaver site folders set up so I can access the db and Connections folders which are outside the wwwroot folder.
The DataAssist extension, by default, chooses the root of the Dreamweaver site, rather than asking where you want to place the folder. In Dreamweaver when you set up a site, you can tell it where to put the Spry Assets folder, it's that functionality I require for the DataAssist Extension. If I was to select the wwwroot folder as the root in dreamweaver, it would work, but then I would have to change the root everytime I wanted to upload any database tweaks I have made.
It's not anything that's broken, it all works fine, it's just this minor tweak that I need to help save some time. I didn't know if there were any more options hidden away that I may have missed.
Thank's again
It is not possible to set where the include files are created. They will always be created at the root of your Dreamweaver site, there is no option to have them created elsewhere.
rob108609
Thank you
ok, Cheers Jason, I will continue with my work-arounds. If you could add that to the wish-list it would be great.
