can someone explain to how data assist integrates with power CMS ?
Thread began 10/30/2009 4:26 pm by mikeybabe | Last modified 10/30/2009 10:12 pm by SOJO web | 508 views | 2 replies |
mikeybabe
Can you integrate the two ? I'm finding power CMS on it's own a bit labour intensive when it comes to managing the pages and was wanting to automatically generate extra pages?
But I don't quite understand how the two would work together ?
The PowerCMS admin area is just inserting records into the db. DataAssist will create a set of pages for you to manage a specific table in your db. If you can please explain a little more about what you are hoping to accomplish as an end result and I will help you with whatever I can.
SOJO webBeta Tester
Mikey,
There is a template that comes with PowerCMS and can be used to add DataAssist functionality to, but that template is for the back-end. If you are trying to automatically generate front-end pages (what the user sees), you still need to create those and insert the include codes that PowerCMS generates - or add recordsets to based on if you do choose to use DataAssist to create additional means for managing content on your site.
I currently have a PowerCMS installation that is customized with DataAssist for various different purposes. For example, I use PowerCMS to handle areas on my pages that I update infrequently or is not time/date sensitive. I use DataAssist to create additional content management of items such as blog entries, photo of the day, or portfolio additions.
Best regards,
Brian
