Reasons for persistent db connection through mysql_pconnect
Thread begun 10/29/2009 2:38 am by mail361522 | Last modified 10/29/2009 10:50 am by anonymous | 1711 views | 1 replies |
mail361522
Hello Webassist. I'm using several of your DW Extensions, including Dataassist for dabase driven websites. However on a new project the webhost doesn't work very well with the mysql_pconnect command. As the number of connections are limited they suggest me to use mysql_connect and to close the connection with mysql_close at end of each script. Why have you choosen to use persistent connections and what can I do to make mysql_connect be the default connection type instead? Thank You for help, I'm no Apache or MySQL expert thats why I just want your extensions to work. Now I'm getting "HTTP 500 - Internal server error" all the time... :confused:
Regards Joa
anonymous
Joa,
The reason it would be used is purely for speed since it would not require connecting over and over... see here for more: 34/
But, yes, the issue you have is also a valid concern for persistent connections.
I think, though, you could simply edit the connect script to use a standard connection with no issue. You could also close the connection at the end of your php page if needed.
Cheers,
Brian
