Godaddy, Autorize.net integration
Thread begun 4/16/2009 9:37 am by stevesmith373400 | Last modified 4/16/2009 10:29 am by stevesmith373400 | 3273 views | 3 replies |
stevesmith373400
After clicking the submit order button, it goes directly to the checkout failure page. I do not believe that it is even going to authorize.net as they have no record of attempts. I inserted the following code as instructed...
in the WA_eCart/Adv_CO_Scripts/AuthNet_PHP.php file locate the following code:
curl_setopt($ch, CURLOPT_POST,1);
and add the following on a new line after it:
//curl_setopt($ch, CURLOPT_PROXYTYPE, CURLPROXY_HTTP);
curl_setopt($ch, 101, 0);
curl_setopt($ch, CURLOPT_PROXY,"http://proxy.shr.secureserver.net:3128");
curl_setopt($ch, CURLOPT_TIMEOUT, 120);
...but it still brings back a failure. Does anyone have a process for fixing this? Authorize.net suggest finding the error code that was returned but my failure page gave no such code or reason for failure. I am so close please help.
stevesmith373400
Also, where do I find the transaction key to ensure that it was put in correctly?
You will find it in the local checkout function on the confirm page.
stevesmith373400
Got it working. Thanks
