Memento Error when starting Dreamweaver CS4
Thread begun 4/16/2009 5:48 am by info23005 | Last modified 9/11/2012 1:35 pm by Jason Byrnes | 23310 views | 21 replies |
info23005
I am receiving the following error when starting Dreamweaver:
While executing onShow in WA_Memento.htm, the following JavaScript error(s) occurred:
In file "WA_Memento":
_MementoNotifications is not defined.
I have many Webassist extensions installed so I'm not sure if a specific extension is causing this... otherwise I would probably simply uninstall and then re-install. I never had a crash or other strange behavior... this just started happening about two days ago.
Any hints or possible solutions would be appreciated. I have started a support ticket as well with the hopes of finding a solution.
This is the winfilecache.dat issue or macfilecache.dat issue if you are on a mac. Search the forums for more details, but essentially you need to close dreamweaver and delete a cache file.
Then when you restart Dreamweaver the problem will be gone. It isn't actually a problem with the code or an an extension. It is a problem with Dreamweaver thinking there is a problem when there isn't. We have reported this to the adobe team and they have assured us it will be fixed in their next update.
The file should exist in your user configuration folder. On PC type "%appdata%" into explorer to find the correct application directory, then browse down to the Dreamweaver version and find the Configuration folder. That is where you will find the offending cache file.
bgspoonz294882
Pardon the dunce, but what does this 'memento' reference... what is 'memento' in this case?
Memento is an interface that is installed with any WebAssist extensions.
It is an RSS feed window where we post announcements, known issues, and product updates that appear directly in Dreamweaver when it is opened.
It's primary purpose is to make sure users get the most recent updates of a given product, but it is also used to promote sales and product launches.
bgspoonz294882
wow... its been awhile since I've used the suite i purchased some time ago, but last I remembered I dont remember this 'memento'. Gonna check for previous forum posting (which i think i did before making this post)
pdouglass267981
How do you uninstall memento from dreamweaver?
Anna Robinson
Here is a thread on disabling Memento:
showthread.php?t=4061
toms016390756
Thanks, it worked for me after i cleared the cache file
--- My baby:
biz295654WebAssist
Originally Said By: Anna Robinson
This isn't a valid link anymore... How can it be disabled?
Anna Robinson
In Dreamweaver, go to either Edit > WebAssist Preferences or WebAssist > Preferences (depends on which product you have installed... we've moved to a high level WebAssist menu with more recent extensions).
Click on Memento. Select Never.
This completely disables Memento. Make sure you also close the Memento floater if you haven't done so already.
