WA_Auth_RestrictAccess issues...
Thread begun 10/22/2009 8:31 am by fdotmedia | Last modified 10/26/2009 11:36 am by Jason Byrnes | 3460 views | 4 replies |
fdotmedia
I have run the wizard a hundred different times with a hundred different variables...
All I need is index.php login to redirect to home.php. That works fine, but, if I kill the session I can navigate directly to the home.php...
groups:
everyone - 2 & 3
admin - 3
The Rule for 'everyone' is:
Allow if <?php echo $_SESSION['userlevel']; ?> in group 'everyone'
The Rule for 'admin' is:
Allow if <?php echo $_SESSION['userlevel']; ?> = 3
It does not work...
I can pull the details out of session to display on the page - even the userlevel...
Anyone have any ideas??? I'm at a loss...
Ted
fdotmedia
Thought I should put the code in here...
<?php require_once('Connections/PathTo.php');?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $PathTo,
"database" => $database_PathTo,
"tableName" => "users",
"columns" => explode($WA_Auth_Separator,"emailaddress".$WA_Auth_Separator."password".$WA_Auth_Separator."orgcode"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userorgcode"]))?$_POST["userorgcode"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"uid".$WA_Auth_Separator."userlevel".$WA_Auth_Separator."emailaddress".$WA_Auth_Separator."orgcode"),
"sessionNames" => explode($WA_Auth_Separator,"uid".$WA_Auth_Separator."userlevel".$WA_Auth_Separator."emailaddress".$WA_Auth_Separator."orgcode"),
"successRedirect" => "landing.php",
"failRedirect" => "dead.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
The the internal pages have:
if (!WA_Auth_RulePasses("everyone")){
WA_Auth_RestrictAccess("not-logged-in.php");
However, like I said, while not logged in I can view the page and it displays everything, except the session stuff...
Any additional ideas?
Most likely your groups have a blank value in them.
it is very easy to add a group member with a blank value and not see it.
Open the Security Assist Access Groups manager and edit each group that you have created.
try to click bellow the last group member to see if there is a blank group member.
If you can select a line with nothing in it bellow the last group member there is a blank one. remove each of the blank group members you find.
the easiest way to see if there is a blank group member or not is directly in the WA_SecurityAssist/HelperGroupsRulesPHP.php file.
fdotmedia
Thanks Jason!
That was it... Thank you...
No worries, glad to hear it's working.
