Customizing SiteAssist Pro template
Thread began 10/20/2009 4:56 pm by stagellis274608 | Last modified 10/20/2009 9:53 pm by Eric Mittman | 983 views | 1 replies |
stagellis274608
Because I was unable to get my older SiteAssist to function properly with Internet Explorer 8, I decided to upgrade to Site Assist Pro, and re-load my entire website. Unfortunately, even though I have chosen the same template on the Pro version, it is different than the older version, and I am unable to customize it. For example, there is no place to input a logo in the Wizard. And on the template, my menu bar cannot be modified to the lenght of the text in each box. Similarly, the page titles for the menu bar drop-down links are longer than the drop down boxes. Lastly, where can I modify the colors for the drop-downs and hover elements. The template seems unalterable. Please advise.
With the new version of SiteAssist Pro you can create your own layouts based on a DW template or a CSS Sculptor preset. You would do your editing to one of these, then incorporate that into your new layout for SiteAssist Pro. You could then update the existing site and just use your new layout.
In addition to the design of the site you can also include your own menu in the layout. This relies on using a preset from CSS Menu Writer. You would craft the look and feel of your menu in here, then use the preset for your new SiteAssist Pro layout.
There is a bit more info on this in the support page for SiteAssist Pro, here is a link:
siteassist/
Check out the customizing your layout with CSS Sculptor and CSS Menu Writer.
