Creating Unvalidated Check Boxes
Thread begun 10/16/2009 2:27 pm by susan358933 | Last modified 10/20/2009 11:46 am by Jason Byrnes | 4039 views | 6 replies |
susan358933
Hello,
I'm having problems adding check boxes to the Contact Form Solution pack. I don't want them to be "required/validated" fields - just optional information.
I've read the support forum, followed threads for jurinski334466 etc. but they all seem to relate to validated fields.
1) I've replaced the "Comments" field on the "out of the box" contact.php form with two check boxes.
<label for="Preflight" >Please send me these documents:</label>
<br />
<span id="sprycheckbox3">
<label>
<input type="checkbox" name="preflight" value="preflight"/>Pre-flight Checklist
<input type="checkbox" name="redesign" value="redesign"/>Redesign Checklist
<?php //WAFV_Conditional contact.php contact(3:)
2) I've removed this line of code from top of page (referring to "Comments")
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
I did NOT include any new code as I don't need an error message for check box fields.
3) I've removed this line of code at bottom of page (referring to "Comments")
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"]});
Replaced with:
var sprycheckbox3 = new Spry.Widget.ValidationCheckbox("sprycheckbox3");
When I click on the "submit" button nothing happens. The page reloads and a new security image is displayed.
Here's a link to form.
contactRADIO.php
FYI: the "out of the box" form works fine on my server here:
contact.php
Can you provide the code for adding a non-validated radio box?
That is, I'm not requiring that clients fill in the check boxes.
I dont think you need to add:
to trouble shoot what the problem is, find the following code:
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
and change it to:
die($WAFV_Errors);
if a validation error is occurring, this will cause the page to display a comma seperated list of numbers corresponding to the validation that is failing.
post this back with a copy of the form page so I can take a look.
susan358933
Validation Code - failing ,2
Hi Jason,
I completed the two changes you requested and reloaded the contact form.
I then completed the form and submitted.
Here are the results:
,2
You can find the updated form at:
contactRADIO.php
Many thanks,
Susan
Can you compress the php page in a zip archive and attach that to your reply so I can look at the code.
susan358933
File attached for Check Box
Hi Jason,
I've attached the .zip file on the contact.php form.
Thank you.
Susan
susan358933
Correct file for check boxes
Jason,
Please disregard first .zip file.
The correct one contactRADIO.php.zip is the one.
SORRY about that...
Susan
So the die statement results are saying that validation 2 is failing:
,2
validation 2 is the email validation
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
make sure you entering a properly formatted email address in the email address form field.
