server VT: compare old data
Thread began 10/16/2009 12:28 pm by info368164 | Last modified 10/16/2009 8:56 pm by Eric Mittman | 917 views | 1 replies |
info368164
Hello,
I have made a form to update the passwords manually with two textbox:
old password...
new password...
Now, I want to compare "old password" with the db field.
In database the data are encripted...
If is possible, how can I do?
I have tried with "Like Entry" but don't work.
Thank you
Luca
I use Classic ASP and VBscript
In order to compare the entered password with the one in the db you will need to encrypt the value that the user enters before you compare it. This should be similar to how your login works.
So whatever function is used to encrypt the value before it is stored in the db initially you should use with the user entered value, then compare that with the value from the db. If the two hashes match then the password is the same.
