posting file name to db not using data assist
Thread began 10/12/2009 2:00 pm by randall390915 | Last modified 10/13/2009 5:28 pm by Jason Byrnes | 3448 views | 3 replies |
randall390915
I am using DFP to upload and rename files from an existing form that wasn't created with data assist. My problem is I can't figure out how to get the new file name into the data base.
Please help. If I have to go in and edit the PHP by hand I can, I just don't know what to do.
Digital File Pro creates a variable called "Server File Name". this variable needs to be used in the insert record behavior.
To get the syntax for the Server File name variable, go to the Bindings panel and expand the WA Uploaded Files (<File Field Name>) group. Then drag the server file name to the page.
You will need to edit the insert record behavior by hand to include the server file name name.
randall390915
I don't get it.
I placed the server file name code into a hidden input named "petImage". but it returns a "null" error.
here is my code:
<?php require_once('Connections/petriever.php'); ?>
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
session_start();
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
$insertSQL = sprintf("INSERT INTO pets (petID, ownerID, petName, petType, petImage, gender, breed, color1, color2) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['petID'], "text"),
GetSQLValueString($_POST['ownerID'], "int"),
GetSQLValueString($_POST['petName'], "text"),
GetSQLValueString($_POST['petType'], "text"),
GetSQLValueString($_POST['petImage'], "text"),
GetSQLValueString($_POST['gender'], "text"),
GetSQLValueString($_POST['breed'], "text"),
GetSQLValueString($_POST['color1'], "text"),
GetSQLValueString($_POST['color2'], "text"));
mysql_select_db($database_petriever, $petriever);
$Result1 = mysql_query($insertSQL, $petriever) or die(mysql_error());
$insertGoTo = "owner.php" ;
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
$vrOwnerID_rsOwner = "-1";
if (isset($_SESSION['MM_Username'])) {
$vrOwnerID_rsOwner = $_SESSION['MM_Username'];
$vrOwnerID_rsOwner = (get_magic_quotes_gpc()) ? $_SESSION['MM_Username'] : addslashes($_SESSION['MM_Username']);
$query_rsOwner = sprintf("SELECT owners.ownerID, owners.firstName FROM owners WHERE owners.email=%s", GetSQLValueString($vrOwnerID_rsOwner, "text"));
$rsOwner = mysql_query($query_rsOwner, $petriever) or die(mysql_error());
$row_rsOwner = mysql_fetch_assoc($rsOwner);
$totalRows_rsOwner = mysql_num_rows($rsOwner);?>
// WA_UploadResult1_1 Start
'UploadFolder' => "images/petsLarge/",
'FileName' => "".((isset($_POST["petID"]))?$_POST["petID"]:"") ."",
'DefaultFileName' => "",
'ResizeType' => "1",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
if(($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)){
WA_DFP_UploadFiles("WA_UploadResult1", "upload", "0", "", "PNG:9", $WA_UploadResult1_Params);
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Untitled Document</title>
<link href="CSS/petriever.css" rel="stylesheet" type="text/css" />
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
</head>
<body>
<form action="<?php echo $editFormAction; ?>" method="post" enctype="multipart/form-data" name="form1" id="form1">
<table align="center">
<tr valign="baseline">
<td nowrap="nowrap" align="right">Pet ID:</td>
<td><span id="sprytextfield1">
<input type="text" name="petID" value="" size="32" />
<span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldInvalidFormatMsg">Invalid format.</span></span></td>
</tr>
<td nowrap="nowrap" align="right">Pet Name:</td>
<td><input type="text" name="petName" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">Pet Type:</td>
<td><select name="petType">
<option value="Cat" <?php if (!(strcmp("Cat", ""))) {echo "SELECTED";} ?>>Cat</option>
<option value="Dog" <?php if (!(strcmp("Dog", ""))) {echo "SELECTED";} ?>>Dog</option>
<option value="Other" <?php if (!(strcmp("Other", ""))) {echo "SELECTED";} ?>>Other</option>
</select>
<select name="select" id="select">
</select> </td>
</tr>
<td nowrap="nowrap" align="right">Gender:</td>
<td valign="baseline"><table>
<tr>
<td><input type="radio" name="gender" value="Male" />
Male</td>
</tr>
<tr>
<td><input type="radio" name="gender" value="Female" />
Female</td>
</tr>
</table></td>
</tr>
<tr><td nowrap="nowrap" align="right">Pet Photo:</td><td><input type="file" name="upload" id="upload" /></td></tr>
<td nowrap="nowrap" align="right">Breed:</td>
<td><input type="text" name="breed" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">Main Color:</td>
<td><input type="text" name="color1" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">Accent Color:</td>
<td><input type="text" name="color2" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">&nbsp;</td>
<td><input type="submit" value="Insert record" /></td>
</tr>
</table>
<input type="hidden" name="ownerID" value="<?php echo $row_rsOwner['ownerID']; ?>" />
<input type="hidden" name="petImage" value="<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>" />
<input type="hidden" name="MM_insert" value="form1" />
</form>
<p>&nbsp;</p>
<p>&nbsp;</p>
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "custom", {pattern:"AAA-00000000", validateOn:["blur"]});
</script>
</body>
</html>
mysql_free_result($rsOwner);
You cant enter the server file name in a form element because it isnt set untill the file is uploaded to the server.
you need to hand edit the insert record server behavior to use the server file name.
This is why it is not supported to use the Dreamweaver insert record behavior with digital file pro.
Also, if you look at the code, the insert record server behavior occurs before the file is uploaded.
you need to rearrange the code so that the file is uploaded before the record is inserted, then hand edit the insert record to use the server file name variable directly instead of the form element.
This isn't a supported feature, so if your not comfortable with PHP coding, you will be better off using DataAssist.
