CS4\Configuration\Shared\WebAssist\Library\WA_Conf iguration.js (error 3)
Thread begun 10/05/2009 2:02 pm by Paul | Last modified 10/06/2009 8:10 am by Paul | 1669 views | 1 replies |
PaulBeta Tester
There does not appear to an 'Other Issues' category, so I've used this category to report the following error as the pages i'm receiving it in all use SecuritiyAssist.
The problem is pretty much straight forward. It seems that since the last recent WA extension updates were applied, I'm now getting an error alert referencing the following path/file:
CS4\Configuration\Shared\WebAssist\Library\WA_Configuration.js (error 3)
(screenshot attached)
The error has worsened in terms of frequency and is now invoking with what appears to be any action in CS4, between 5-8 times, rendering normal use of CS4 virtually impossible.
There appear to be other references to this issue (or at least very similar instances) across the forum, but no absolute solution exists.
I have tried deleting the wincache file too, but this has made no difference.
Grateful for any assistance.
Thank you, Paul.
PaulBeta Tester
to anyone with same issue...
I have resolved this by renaming the configuration folder in
C:\Users\<username>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US.
it does mean re activating each extensions again, but one can go through them one at a time to isolate the problematic one.
