Lookup tables & inserting records
Thread begun 4/08/2009 2:25 pm by akstudio | Last modified 4/09/2009 7:04 am by Ray Borduin | 4056 views | 2 replies |
akstudio
Hi
I have a question.
Basically.. how can submit one form into two tables.
The primary key/foreign key across 2 tables is needed in this situation, but table 'B' doesnt update based on the records inserted into table 'A' using Data Assist.
Of course I can cascade the deletion of a record in table 'A' and have it removed in table 'B' - but how can I do the reverse.... insert into 2 tables based on one form.
I'm using DWCS4 and have the webassist suite to work with.
Ian
Can't you just add to Insert Behaviours onto a page that are both triggered by the same button - but on the first one you would not add a redirect page so it would execute the second insert behaviour?
Ian
That is correct Ian, you can also use the "maintain relational table" server behavior if you want to do a one to many relationship in the two tables based on a multiselect list or checkbox group.
