PNG files not maintaining transparency when uploaded with DFP2
Thread begun 10/03/2009 11:38 am by hmyrick308645 | Last modified 10/05/2010 11:34 am by Jason Byrnes | 8331 views | 15 replies |
hmyrick308645
I am using DFP2. I have set up an upload and set the file format to "Format: Keep existing format". However, if I upload a PNG file with a transparent background, the image ends up flattened with a black background in place of the transparent area.
I also tried "Convert to PNG" just to see what would happened. Same result.
How can I get PNG images to maintain their transparency when uploaded through DFP?
pledge204907
PNG transparency
I am having exactly the same problems. Is there a workaround to fix this issue?
I have created a technical support incident so we can look int this issue with you. To view and edit your support incident, please log in your support history:
DarylBeta Tester
Was this ever resolved as I am now having this problem.
JBWebWorks
I heard that a work around is to upload the png file as a file instead of a 'web image'
DarylBeta Tester
This work around does work.
Thank you
Dave BuchholzBeta Tester
Is there a fix in the works for this ? On the current project I am working on I have had to use DMX Zone's Pure PHP Upload Bundle to get round this issue and it is a pain as I have had to change my admin panel files to cope with this.
Yes, this has been logged as a bug and a fix will be released.
Thanks for the update, Jason
You're welcome.
