inserting image file name and server file name into db
Thread began 10/01/2009 7:12 am by julie.skelton390139 | Last modified 11/03/2009 6:09 pm by Jason Byrnes | 2281 views | 12 replies |
julie.skelton390139
I have created the admin pages using DataAssist and set up an image upload from the insert record page using DFP2. I followed the instructions in the help pdf dfp_da_insert_update_ht.pdf However the instructions do not give full details of how/what to put in the server behavior field under the column for my image thumbnail field in the database. Setting the value to <?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?> works great for the main image, however as I have set up the upload to work from one upload automatically creating the thumb image (renaming the file to picname_thumb.jpg) I don't know what to enter for the value of the server behavior to make it add the _thumb bit which is automatically added.
So to summarize the pic is uploading correctly and automatically creatiing a _thumb version from the one upload, and the file name is being inserted into the database main pic field correctly however I don't know how to get it to add the _thumb filename into the thumb filename field of the database
When you set digital File Pro to upload multiple copies of a file to different folders, there are Server File name bindings created in the WA Uploaded Files (File Filed name) bindings group.
Say for example that I have a Thumbs and Large folder that I am uploading to, the Bindings groups will contain bindings titled:
Thumbs[FileName]: Server File Name
large[FileName]: Server File Name
For the database column you wish to store the thumbnail in, bind to the Thumbs[FileName]: Server File Name, for the column you wish to store the large image name, use the large[FileName]: Server File Name binding.
julie.skelton390139
I could not find Thumbs[FileName]: Server File Name from the image when I double click on Insert Record from Server Behaviours (Page 2 of options > then clicked the thumb column and lightening bolt > WA Upload files - it only lists Server File Name for the main image not the thumb.
I have worked around it for now making it call the thumbnail version the same as the main image eg [filename] instead of [filename]_thumb, but it places it in a different directory. Need to work on the update page now so not sure how this will work with your instructions as it mentions the hidden field etc??
I have created a support ticket for you so we can look into the problem, to view and edit your support ticket, please log into your support history:
supporthistory.php?
troyd
I am having the same issue. What was the resolve for this?
Everything is uploading and creating the large image and thumb but the large image filename is written to both the large and thumb column in my table.
I don't see any thumb server file name in the bindings for that column.
TroyD
troyd
I am not having any luck figuring this out. Still don't have a server file name choice for the thumbs.
Here are some more details. First, I'm using DFP 2.0.2.
I have one WA upload behavior with two images being generated. A large and a thumb. I will paste my code below.
Upload behavior.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "images/gallery/",
'FileName' => "[FileName]_large",
'DefaultFileName' => "",
'ResizeType' => "4",
'ResizeWidth' => "700",
'ResizeHeight' => "525",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'UploadFolder' => "images/gallery/thumbs/",
'FileName' => "[FileName]_thumb",
'ResizeWidth' => "300",
'ResizeHeight' => "225",
// WA_UploadResult1_2 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct
("WA_UploadResult1");
if(isset(
$_POST["Submit"])){
WA_DFP_UploadFiles("WA_UploadResult1""image""0""""JPG:70"$WA_UploadResult1_Params);
Insert behavior. (Data Assist 2.0.5)
// WA Application Builder Insert
if (isset($_POST["Submit"])) // Trigger
$WA_connection $localhost;
$WA_table "tblGallerysp";
$WA_sessionName "tblGallerysp_id";
$WA_redirectURL "results.php";
$WA_keepQueryString false;
$WA_indexField "id";
$WA_fieldNamesStr "id|imagethumb|imageorig|labeltext";
$WA_fieldValuesStr "".((isset($_POST["id"]))?$_POST["id"]:"")  ."" "|" "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]  ."" "|" "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]  ."" "|" "".((isset($_POST["imagelabel"]))?$_POST["imagelabel"]:"")  ."";
$WA_columnTypesStr "none,none,NULL|',none,''|',none,''|',none,''";
$WA_fieldNames explode("|"$WA_fieldNamesStr);
$WA_fieldValues explode("|"$WA_fieldValuesStr);
$WA_columns explode("|"$WA_columnTypesStr);
$WA_connectionDB $database_localhost;
mysql_select_db($WA_connectionDB$WA_connection);
  if (!
session_id()) session_start();
$insertParamsObj WA_AB_generateInsertParams($WA_fieldNames$WA_columns$WA_fieldValues, -1);
$WA_Sql "INSERT INTO `" $WA_table "` (" $insertParamsObj->WA_tableValues ") VALUES (" $insertParamsObj->WA_dbValues ")";
$MM_editCmd mysql_query($WA_Sql$WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = mysql_insert_id();
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL'?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
Should I just change this line in the insert?...
$WA_fieldValuesStr = "".((isset($_POST["id"]))?$_POST["id"]:"")  ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]  ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]  ."" . "|" . "".((isset($_POST["imagelabel"]))?$_POST["imagelabel"]:"")  ."";
To...
$WA_fieldValuesStr = "".((isset($_POST["id"]))?$_POST["id"]:"")  ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1_1"]["serverFileName"]  ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1_2"]["serverFileName"]  ."" . "|" . "".((isset($_POST["imagelabel"]))?$_POST["imagelabel"]:"")  ."";
I'll try it, but is this correct?
TroyD
Yes, using:
Should get the large file name
and:
should return the thumbnail file name.
troyd
Thanks Jason,
I tried this and now I'm getting an error. Plus, when I look in the insert wizard, it has my server file names mismatched. I can't see what the problem is. Can you take a look?
Error after inserting record with upload.
Notice: Undefined index: WA_UploadResult1_1 in /Applications/MAMP/htdocs/SandboxPHP/lightbox/insert2.php on line 81
Notice: Undefined index: WA_UploadResult1_2 in /Applications/MAMP/htdocs/SandboxPHP/lightbox/insert2.php on line 81
Warning: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/SandboxPHP/lightbox/insert2.php:81) in /Applications/MAMP/htdocs/SandboxPHP/lightbox/insert2.php on line 97
Here is my new line (81) it's referencing.
I don't see any extra spaces in my php. The problems is most likely staring my in the face.
OH, one other detail. Now, it's not writing anything into the image columns. Which stands to reason, but I figured I would add that here.
TroyD
Please send the full php page so I can see the code in context, not just the one line.
troyd
Sure, here you go. Hope it was ok I pasted it here.
<?php require_once('../Connections/localhost.php'); ?>
require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? "'" doubleval($theValue) . "'" "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
mysql_select_db($database_localhost$localhost);
$query_rsGallerySP "SELECT * FROM tblGallerysp ORDER BY id DESC";
$rsGallerySP mysql_query($query_rsGallerySP$localhost) or die(mysql_error());
$row_rsGallerySP mysql_fetch_assoc($rsGallerySP);
$totalRows_rsGallerySP mysql_num_rows($rsGallerySP);?>
if(isset(
$_POST["Submit"])){
$WA_fieldNamesStr "id|imageorig|imagethumb|labeltext";
$WA_fieldValuesStr "".((isset($_POST["id"]))?$_POST["id"]:"")  ."" "|" "".$WA_DFP_UploadStatus["WA_UploadResult1_1"]["serverFileName"]  ."" "|" "".$WA_DFP_UploadStatus["WA_UploadResult1_2"]["serverFileName"]  ."" "|" "".((isset($_POST["imagelabel"]))?$_POST["imagelabel"]:"")  ."";
  if (!
  if (
    if (
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Gallery Insert</title>
<style type="text/css">
#galleryresultscontainer {
    width: 900px;
    margin-right: auto;
    margin-left: auto;
    text-align: center;
.thumbswrap {
    width: 200px;
    text-align: center;
    padding: 5px;
    float: left;
.labeltext {
    font-family: Arial, Helvetica, sans-serif;
    font-size: 12px;
    margin-top: 2px;
    float: left;
    width: 100%;
    background-color: #CDC9EB;
#formwrap {
    width: 900px;
    margin-right: auto;
    margin-left: auto;
    text-align: center;
#formwrap label {
    font-weight: bold;
    font-size: 12px;
    margin-right: 5px;
</style>
</head>
<body>
<div id="formwrap">
  <form action="" method="post" enctype="multipart/form-data" name="form1" id="form1">
    <input name="id" type="hidden" id="id" value="" />
    <label>Choose Image:
    <input type="file" name="image" id="image" />
    </label>
    <label>Image Label:
    <input name="imagelabel" type="text" id="imagelabel" size="45" />
    </label>
    <input type="submit" name="Submit" id="Submit" value="Submit" />
  </form>
</div>
<?php do { ?>
  <div id="galleryresultscontainer">
    <?php if ($totalRows_rsGallerySP 0) { // Show if recordset not empty ?>
      <div class="thumbswrap"><img src="images/gallery/thumbs/<?php echo $row_rsGallerySP['imagethumb']; ?>" alt="" name="imagepreview" width="200" id="imagepreview" />
        <div class="labeltext"><?php echo $row_rsGallerySP['labeltext']; ?></div>
        <div class="labeltext"><a href="delete.php?id=<?php echo(rawurlencode($row_rsGallerySP['id'])); ?>">Delete</a></div>
      </div>
      <?php // Show if recordset not empty ?>
  </div>
  <?php } while ($row_rsGallerySP mysql_fetch_assoc($rsGallerySP)); ?>
</body>
</html>
mysql_free_result
($rsGallerySP);
Thanks so much,
TroyD
