Security Assist database file
Thread begun 9/30/2009 6:17 pm by madelectrical386948 | Last modified 4/07/2011 8:23 am by Jason Byrnes | 16244 views | 38 replies |
madelectrical386948
I have downloaded the security assist extension and I am looking for the correct database to use with this. Is there one already made? I am on the 2nd video and it shows selecting a user field and the blue sky database doesn't have that.
Do I have to make it, or is there a database for this training that I can use.
thx
Mike
Office Guy-172461
If you go to your Download area and click on:
Solution Recipes: Support Files
You will find the files you need.
neil186288
It's really hard to find! In your downloads page, do you have a User Registration Solution Pack? I think they provide that when you buy the Security Assist Extension.
Downloading that will give you a zipped folder called 'UserRegistration100', and in that there is a Database folder that contains the Users.sql.
The Sql contains just one table (users) so you should presumably dump this in to your BlueSky database.
It would be easier to all if a copy of this were in the Data Assist support files. If you can't find it I'll provide you with it, but it should be there
neil186288
Office Guy, do you have an email address I can contact you on?
Forget it.
Office Guy-172461
It's better to use the one that comes with the extension you are using. The Solution files are located on the same page that you download the extension.
SecurityAssist: Solution Recipe Files (2,787 Kb)
A .zip file containing the databases and start and finish files for PHP, ASP-JS, ASP-VB and ColdFusion. Use these files to follow along with the User Level Authentication Solution Recipe on your own machine.
neil186288
Originally Said By: Office Guy-172461
I don't think that the sql table that madelectrical is looking for is there. It contains the blue_sky_music.sql that he already has - (this doesn't have a 'users' table) - but not the User table that is in the video. I'm fairly sure it's in the User Resolution Solution Pack which has it's own section on the 'Your Account' 'Download Products' page. Perhaps the users.sql file could be included in the SecurityAssist download page sometime in the future?
madelectrical386948
You are correct Neil.
I have downloaded the files that you suggest Office Guy. The database doesn't have the user field, but the php files do not look like the video files. Different applications.
So to truly follow with the video, can I get the correct database and also the php files?
thx
Mike
madelectrical386948
Sorry about the 2nd post.
Neil, I tried looking for the UserRegistration100, and I can't find it.
I have looked for it thru the securityassist area and just thru downloads when I get on.
Any other ideas?
thx
Mike
neil186288
Hiy madelectrical,
That's odd. Do you have the 'User Registration Solution Pack' showing on your 'Download Products' ( downloadcenter.php ) page?
If so:
click that - and then on the next page - click the 'User Registration Solution Pack' (again) and download the 'Complete Files' . When you unzip that, you will have the folder 'UserRegistration100'. Inside that there is a folder called 'Database', and finally, inside that is a 'users.sql' file. As far as I know, - and I hope someone will correct me if I'm wrong - this is the closest you'll come to the file you need in the resources you've (we've) been given.
If not: (and this should have happened earlier - I apologise) this is it:
CREATE TABLE `users` (
`UserID` int(11) NOT NULL auto_increment,
`UserEmail` varchar(500) default NULL,
`UserPassword` varchar(500) default NULL,
`UserFirstName` varchar(50) default NULL,
`UserLastName` varchar(50) default NULL,
`UserCity` varchar(90) default NULL,
`UserState` varchar(20) default NULL,
`UserZip` varchar(12) default NULL,
`UserEmailVerified` tinyint(1) default '0',
`UserRegistrationDate` timestamp NULL default CURRENT_TIMESTAMP,
`UserVerificationCode` varchar(20) default NULL,
`UserIP` varchar(50) default NULL,
`UserPhone` varchar(20) default NULL,
`UserFax` varchar(20) default NULL,
`UserCountry` varchar(20) default NULL,
`UserAddress` varchar(100) default NULL,
`UserAddress2` varchar(50) default NULL,
PRIMARY KEY (`UserID`)
Copy that code into a plaintext (Notepad?) file and save it as users.sql
Or just paste the code into the SQL query area in your mySql (i do it via phpMyAdmin) in your blue sky database.
You may need to adjust the sql a little bit, but that would be easy to do, and I think it's pretty much up to what is required for the tutorial.
Hope this helps.
Neil H
PS Have also put the User Registration zip file: here LINK REMOVED BY Jason Byrnes
Neil, Please do not post links to the Source files for the solution packs in a public forum such as this. This violates the EULA.
The support files in the Download center are for the User Level Authentication Solution recipe. The Getting started using Security Assist recipe doesn't have any pages or a database that go along with it.
The first part of the recipe has you run the Security Assist wizard to create your pages. You can use the Blue Sky Music database which contains a visitors table to use.
