required field validation error
Thread begun 9/24/2009 7:58 am by conversationmail388568 | Last modified 10/12/2009 10:26 am by t297098 | 6791 views | 7 replies |
Hello, need to get this fixed! :)
From a previous thread that addressed my problem this
showthread.php?t=3172
this what I've done.
I copied WAFV_Required_C.js to
C:\Program Files\Common\Adobe\Installers\[Adobe Number]\Adobe Dreamweaver CS4\Configuration\Commands\
which did not fix the probelm. I do not have a directory called
C:\Program Files\Common\Adobe\Installers\[Adobe Number]\Adobe Dreamweaver CS4\Configuration\Behaviors\Actions\WA Validation Toolkit\Apply Client Validations
on my PC. I'm using XP pro.
Problem still exists.
Thanks for your help!
See this post:
showpost.php?p=14450&postcount=9
it has the correct path.
Also see the Known Issues tab in the Download Center for form builder, there is a known issues pack there that contains the correct path.
no luck
Hello. The path you showed me at show...50&postcount=9 is for a Mac. I'm on a PC. I tried to look for the mention of this problem in known issues but had no luck.
I put the WAFV_Required_c.j file in these 2 directories and restarted Dreamweaver.
C:\Program Files\Adobe\Adobe Dreamweaver CS4\configuration\Behaviors\Actions\WA Validation Toolkit\Apply Client Validators
-and-
C:\Documents and Settings\HP_Administrator\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration\Commands
I should note that the WA Validation Toolkit\Apply Client Validators directories did not exist so I had to create them.
image of my error
attached is a pic of the error I'm getting...
The known issues document in the download center contains the correct locations.
it should go in:
C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Behaviors\Actions\WA Validation Toolkit\Apply Client Validations\WAFV_Required_C.js
and:
C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration\Commands\WAFV_Required_C.js
still not working :(
Thanks for the info, I never did find that document.
Sadly I put the .js file in both locations you mentioned and restarted DW and the required validation gives m the same error. Maybe a reboot is in order?
I sure hope to get this fixed soon.
Thanks for your help so far.
I guess I should mention I have not purchased the validation tool kit as I thought it was included with the form builder in the Super Suite. Is this correct?
I have created a support ticket so We can get to the bottom of this. To view and edit your ticket, log into your support history:
t297098
Worked
This solution worked for me 2
