Theme Array has no properties
Thread begun 9/17/2009 11:20 am by info72555 | Last modified 9/18/2009 8:59 am by Jason Byrnes | 2592 views | 3 replies |
info72555
I just attempted to edit an existing form. When it tried to generate the code (progress bar), I received an error message and the form did not change. I am referencing the contactus.php template from the Contact Solution Pack in the WAUE php file.
I would like to work with an existing form because it's already working and I had a bit of trouble getting all te right settings. What do I need to do?
Did you perhaps install an older extesnion after installing form builder?
Try removing form Builder From the extesnion manager, then reinstalling it.
after reinstalling, delete the Dreamweaver cache file from the users configuration folder:
info72555
Theme array error
I only ever installed the extensions once so that should not be the problem. I have edited a form from the Contact Solution Pack that is working fine. (It's using a template to create HTML output.) Any chance that the code CSS Formbuilder wants to edit and the code from the Solution Pack are not compatible?
We tested using Form builder on the contact from solution pack, so that should not be a problem.
can you send a copy of your page in a zip file so I can do some testing?
