blocking duplicate entries
Thread begun 9/14/2009 12:16 pm by un33k9309513 | Last modified 3/10/2010 11:01 am by un33k9309513 | 7438 views | 13 replies |
un33k9309513
I am trying to stop dulicate entries and I have the following server validation so far but it is blocking all entries. I also do have a recordset that filters based on the two columns I would like to block duplicate entries from.
if (isset($_POST["Submit"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_merch_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM(($totalRows_rsDuplicates) . "",0,0,"",",.",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"merch");
You have set the minimum and maximum to 0, try setting the minimum to -1 and the maximum to 0.
also make sure that the recordset code is before the validation code. If the recordset is created after the validation is performed, it will always fail.
un33k9309513
I did set the min to -1 and that may have done it but I'm not sure because,
I have a select list that shows and hides two divs, but now it doesn't switch between the two to show/hide one or the other, this is what it has
<select name="type" id="type" onchange="WAValidateRX(document.forms[2].type,'select','/2/i','- Invalid entry',document.forms[2].type,0,true);WAValidateHD(document.forms[2].type,'sub_url',true);WAValidateRX(document.forms[2].type,'select','/2/','- Invalid entry',document.forms[2].type,0,true);WAValidateHD(document.forms[2].type,'sub_code',false)">
<option value="1" selected="selected">Code</option>
<option value="2">Print</option>
</select>
I noticed that after I added another form on my page that all the 1's where changed to 2's in the above so it used to be like this:
<select name="type" id="type" onchange="WAValidateRX(document.forms[1].type,'select','/2/i','- Invalid entry',document.forms[1].type,0,true);WAValidateHD(document.forms[1].type,'sub_url',true);WAValidateRX(document.forms[1].type,'select','/2/','- Invalid entry',document.forms[1].type,0,true);WAValidateHD(document.forms[1].type,'sub_code',false)">
</select>
By the way the duplicate entry is for both of these option values. These are regular expression validations on the select list like so in the behavior window:
onChange ----- regular expression
onChange ----- show/hide layer
Is there a place where I need to change a [1] to [2], I also just noticed if I have not submitted for a specific record it all works fine, but if I submit for a record then this problem occurs.
thanks
It is using the forms[] collection which is an array containing all of the forms on the page.
If you a by the fact is has changed the [1] to a [2] it suggests that you added another form to the page before the one with the select lists in it.
it is hard to tell what the problem may be with out seeing the page, do you have a link you can send so I can see the code in context.
un33k9309513
Yes the form I added is before the select list. I am running this page locally so I can upload the file but I didn't want to post it public. Is there a place that I need to update to the [2] also, I already updated the server validation and client validations to use [2].
if you can advise
I am creating a support ticket so we can look into the issue further.
To view and edit your support ticket, log into your support history:
un33k9309513
Thanks for the help Ray,
so I am updating this here As far as I can remember I hope I'm not missing anything here- the fix Ray helped me with is we had to change everywhere you see this:
.forms[1] to something else and that got it working. So,...
FROM THIS:
</select>
TO THIS:
<select name="type" id="type" onchange="WAValidateRX(document.something.type,'select','/2/i','- Invalid entry',document.something.type,0,true);WAValidateHD(document.something.type,'sub_url',true);WAValidateRX(document.forms[1].type,'select','/2/','- Invalid entry',document.something.type,0,true);WAValidateHD(document.something.type,'sub_code',false)">
</select>
thanks
un33k9309513
Well I thought I had it right, until I tried to submit an entry that was not in the table for a particular storeID but it was there for another storeID. So how can I block duplicate entries in the ccode column but only for the same storeID?
Here is the recordset I have for the duplicates recordset.
SELECT ccode
FROM visitorcodes
WHERE ccode = colname OR print = printcol
would I just have to set up something else in the WHERE clause like
WHERE ccode = colname OR print = printcol AND storeid = storecol
and then in the variable a $GET or $POST ?
I am trying to figure this out but it's kind of over my head
Yes, that is it exactly.
Is the storeid stored in a post variable or a session variable?
Say you have a session variable named "storeid", the run time value for the storecol variable would be set to :
$_SESSION['storeid']
un33k9309513
I don't think I have a session variable for storeid, but I used WA insert record wizard and I have the following set up:
session variable:
key column: VID
store as: vis_VID
I changed to this:
key column: VID
store as: vis_storeid
on my page's recordset I then put in:
$_Session['storeid']
For the type, I tried text and numeric neither worked.
The key column VID in my table is Not the storeid column, the key column is just there but I'm not using it for anything special I don't think.
When someone inserts a record it goes in the table but in WA insert record wizard on page 2 I have the storeid column set to this:
<?php echo $row_recordall['storeid']; ?>
I don't know how to check if the storeid is stored in a post or session variable..
anything I am not looking at right? Should I create a session variable, and how would I do that?
