Site Assist Professional 1.0.7
Thread begun 9/11/2009 10:25 pm by michaelf0199272 | Last modified 9/17/2009 6:06 am by michaelf0199272 | 2159 views | 2 replies |
michaelf0199272
Q:How do I edit out the both (i) topNavigation_bg.jpg and (ii) topnav_background.jpg images on the template so I can replace them with mine?
For example I will like to substitute the image attached with somthing else.
I have resolved this issue by editing out the background picture from both content.css and home.css.
Michael
lrawlins367093
Editing images
They are in the siteassistpro_images folder on your site.
For me the solution is to make my image the same size and then replace the default images.
Have fun!
michaelf0199272
Irawlings -- Yes I know where they are at. I was looking to edit the picture out of the template -- this means I had to do the edit on the .css page that applies the picture to the pages, in my case it turns out to be the home.css.
This is where you edit the picture out from and not from the siteassistpro_images folder. If you did what you just suggested -- Yes the image will be removed out of the image folder, but will still be on the pages -- only that it will be "X" -- which indactes image that it is not found or image that has been moved.
The real answer to my request was to edit the home.css, which I figured out on my own. However, let me thank you for at least trying to help.
Michael
