CSS Sculptor 2.0.5 - Does not Install
Thread begun 9/11/2009 1:55 pm by contactus306424 | Last modified 9/11/2009 4:47 pm by contactus306424 | 2633 views | 4 replies |
contactus306424
No success installing CSS Sculptor 2.0.5. Using Windows VISTA & Adobe Web Premium CS4.
The installation process starts and the installation progress bar gets to about half way then clears showing the extension manager application again without CSS Sculptor 2.0.5 being installed.
Reinstalled CSS Sculptor 2.0.4 and all worked fine. I reported this issue to WebAssist and was told to use the Forum, so here I am.
Is there a work around to be able to install CSS Sculptor 2.0.5?
Dani Chankhour
I recommend deleting your configuration folder and reinstalling the extension. This post have some instruction on how to delete you config folder:
showpost.php?p=15525&postcount=2
let me know if you are still seeing the issue.
contactus306424
I renamed the configuration folder and tried reinstalling the extension CSS Sculptor 2.0.5. I got the same result as before, I then reinstalled CSS Sculptor 2.0.4 and all worked fine.
Dani Chankhour
The only other installation issue that could happen is the path to the extension. Please try downloading and saving the extension to your Desktop first, and then open the extension manager and try installing the extension by clicking the install button from the extension manager.
contactus306424
Did that, downloaded the extension my Desktop first then opened extension manager and installed from there and it all worked fine.
Thank you for your assistance...
