Error messages
Thread began 9/11/2009 2:07 pm by WilliFixit | Last modified 9/11/2009 5:16 pm by Dani Chankhour | 585 views | 3 replies |
WilliFixit
Error messages
I have an existing form (Built with CSS Form Builder) and I am getting error messages when I do the following:
1. Select the form
2. In the Properties panel click Edit Contents
3. Select the Group 1, and click Edit
4. Select Set 1 of Line 3
5. Change the Validation Error Message
6. Click Finish
7. On the pop up message box, accept the defaults and click OK (I don't want to save a new preset.)
8. Back on the Edit Form Content dialog, click Finish.
9. Click Finish, and then OK on the message about new preset.
>>>>Error message: 9-11-2009 11-43-39 AM.jpg
10. Then some processing and...
>>>>Processing hangs: 9-11-2009 11-43-59 AM.jpg
If I try this again, I don't get error messages, but the processing seems to hang: 9-11-2009 12-06-33 PM.jpg
Please advise...
Dani Chankhour
Could you specify the type of the form that you have started with. I was not able to reproduce the error using the Registration form.
WilliFixit
See attached image. Does that provide what you need?
Dani Chankhour
I have tried reproducing the issue on Vista and MAC 10.6 on CS4 with no luck.
Could you please try to recreate the form on a different page and see if you can reproduce the error.
I would also recommend deleting your configuration and reinstalling the extension:
showpost.php?p=15525&postcount=2
If you are still seeing the error, please post back with the OS and DW version you are running.
