Multiple Shipping costs
Thread began 9/11/2009 6:56 am by kelly291243 | Last modified 10/07/2009 4:02 pm by Jason Byrnes | 1441 views | 15 replies |
kelly291243
I would like to add a 2nd option for shipping on my eCart website. At the moment I only have a single shipping cost of £3.75 which is applied to all orders. I am based in the UK and would like to have a shipping cost of £5.75 for all orders I need to ship outside of the UK so I would have:
UK Shipping - £3.75
International Shipping - £5.75
Please could you tell me the best way to do this? Do I need to put this on the cart page or the checkout page? Could I set the shipping cost based on the country chosen from the drop-down menu on the checkout page or just give a checkbox for those outside the UK to tick and have that update the shipping cost?
I understand that a Session may have to be created for this but I am very new to session variables so would appreciate a real step-by-step approach.
The website I have created with eCart is www.tube-shop.com
many thanks for your time
Kelly
A session variabel is already created that can be used for this.
In the eCart object you will need to create two shipping charges, one for UK orders, one for international orders:
UK Orders:
Triggers:
Session Variable Exists -
Session Variable name: [eCartCheckoutForm_shipping_country]
AND
Based on Session Variable Value -
If the value of session variable [eCartCheckoutForm_shipping_country] is [=] a value of [UK]
Calculation:
Flat Rate charge of 3.75
International Orders:
Triggers:
AND
If the value of session variable [eCartCheckoutForm_shipping_country] is [!=] a value of [UK]
Calculation:
Flat Rate charge of 5.75
kelly291243
Thank you for the response.
I have tried to add the shipping options you have suggested but at the moment I am getting the following error message:
Microsoft VBScript compilation error '800a0401'
Expected end of statement
/WA_eCart/Adv_CO_Scripts/PP_PayProUK_VB.asp, line 143
httpObj.setRequestHeader "X-VPS-CLIENT-TIMEOUT, "30"
I would like to double check to see if I am sentering the information correctly.
1. Am I to enter the session variable name and value with square brackets around them?
2. For the international shipping you have suggested I put [!=] but this option does not appear in teh drop down list. I get teh following options
I am guessing I should be using [<>] as I think i'm trying to pick thos countries that are not UK.
I also have other shipping options that I have set up so I will put the details below:
1. UK Shipping
Total number of items > 0
AND Subtotal of items < 65.22
AND If session variable exists: [eCartCheckoutForm_shipping_country]
AND If session variable [eCartCheckoutForm_shipping_country] = [UK]
Calculation - Flat Rate 3.75
This gives a shipping fee of 3.75 for all orders under £65.22 to be shipped to the UK
2. UK Shipping with discount
UK Shipping
AND Subtotal of items >= 65.22
Calculation - Flat Rate 0
This gives a shipping fee of £0.00 for all orders over £65.22 to be shipped to the UK
3. International Shipping
AND If session variable [eCartCheckoutForm_shipping_country] <> [UK]
Calculation - Flat Rate 5.75
This gives a shipping fee of £5.75 for all orders shipped outside the UK
To fix the error change line 143 to:
httpObj.setRequestHeader "X-VPS-CLIENT-TIMEOUT", "30"
I'm looking at my copy of that file and it is correctly coded. I cant see why yours would be missing the quotation mark.
Your rules look to be correct, though the second one is not really needed.
kelly291243
OK, that's great. Could you please confirm whether I need to use the Square brackets or not?
Thanks again
Kelly
I put the square brackets in to highlight form input. you should not enter them, just the information inside the square brackets.
kelly291243
The shipping charge is still not working correctly. I no longer get the error message so that part is fixed, I just think it's the shipping rules. Just to confirm again what my shipping rules are, I have listed them below in the order they appear in the shipping tab in my cart object:
1. UK Shipping
UK Shipping
So if I go through my rules:
1. If subtotal of cart is less than 65.22 and country is UK then charge £3.75 shipping
2. If subtotal of cart is equal to or greater than 65.22 and country is UK then charge £0 shipping.
3. If country is not UK then charge £5.75
You mentioned in a previous reply that the second rule doesn't need to be there but how can I add free shipping if an order is over a specific value and in UK only?
kelly291243
I figured out why the rules were not working :)
I was using the value for eCartCheckoutForm_country as UK but it should have been GB.
I have the page working fine now, thanks for all your help.
However, my client has now asked for another option which I will require the customer selecting an option.
Currently, my shipping options are:
Standard UK Shipping - £3.75
Free shipping on orders over £75 inc vat
International Shipping £5.75
My client now would like a guaranteed next day shipping option with a value of £5.75. I am guessing that if the customer clicks a checkbox for next day shipping I will need to add £2 to the standard UK shipping charge. What would be the best way to impliment this and which page would this appear on, the cart page or confirm page?
Many thanks again
Kelly
add the checkbox to the checkout page.
also add a hidden form element with the same name to the confirm page:
to checkout:
<input type="checkbox" name="nextDay" value="1" />
to confirm:
<input type="hidden" name="nextDay" value="<?php echo isset($_POST['nextDay']?$_POST['nextDay']:""); ?>" />
On the confirm page, add a set session value server behavior. On the Server behavior panel, click the plus button and select eCart -> General -> Set Session Value.
For both the trigger and the value, click the lightning bolt and select the nextDay form element.
set the name of the session variable to "nextDay"
now create a new shipping rule using the Session Variable exists "nextDay" trigger and based on session variable value trigger:
if the session variable "nextDay" is "=" to a value of "1"
and set a flat rate charge of 5.75
kelly291243
Hi Jason and thank you so much for the help you have given me.
I have added the checkbox to the checkout page with the correct values and the hidden field to the confirm page, again with the correct values.
Unfortunately, I am still stuck on one small point and that is setting the session value. For some reason when I click on set session value server behavior my form element does not appear anywhere in the list. I get the usual WA sessions appear aswell as my ecart object and the local checkout response elements but not my 'nextday' form element. How would I manually enter the data in the trigger field and the value field.
I am coding in ASP rather than PhP and I know from previous experience that the form element would normally appear if the page was PhP but not necessarily in ASP.
With your help, I feel I am very close to completing my shipping charges so hope this will be the last request for help.
Thanks again
Kelly
