Parse error
Thread begun 8/27/2009 11:12 am by gary917 | Last modified 8/28/2009 10:51 am by Eric Mittman | 1783 views | 1 replies |
gary917
Parse error
I have created a simple page with just the form and I am receiving the following error...
Parse error: syntax error, unexpected ')' in form.php on line 60
To help work around the problem for now you should update the code on this line to look like this:
if (0 == 0) {
You should also update the same code that appears on lines:
83
131
166
This should allow you to test the pages. Please post back and let us know what settings you used and what selections you made in the wizard to create this form. I will use this info to test and try to find out if what you are experiencing is a bug or some other issue.
