Email Password - add fields besides email?
Thread began 8/18/2009 8:56 pm by stuff269776 | Last modified 8/26/2009 12:14 pm by Jason Byrnes | 763 views | 3 replies |
stuff269776
My "Email Password" page is now working great - except that I have a problem with multiple registered users who use the same email address (families with a shared email address, for example). They get the first user ID / password in the database with that email address instead of the specific one that actually applies to the particular individual.
Unfortunately, changing the membership rules to require unique email addresses is out of the question so I have to change my password request form to include both last name and first name in addition to email address.
I've added the new fields to the form (see code below) and should be able to add the info to the email body text but can anyone please tell me how to add the extra fields to SecurityAssist's search/filter code? Is the code adaptable to this additional requirement?
Below is the relevant code (with generic replacements for site-specific identifiers). The site is hosted on bluehost.com (Linux, MySQL 5.0, PHP 5.2).
Thank you,
J.
<?php require_once('../Connections/connSAMPLE1.php');?>
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
function WA_SecurityAssist_Email_1_SendMail($WA_Auth_Parame ter){
$WA_MailObject = WA_SecurityAssist_Definition("mail.testcase.org"," 25","SAMPLE@testcase.org@ymail.testcase.org","","" ,"");
$WA_MailObject = WA_SecurityAssist_SendMail($WA_MailObject,"","","" ,$WA_Auth_Parameter["toAddress"],"",$WA_Auth_Parameter["fromAddress"],$WA_Auth_Parameter["subject"],$WA_Auth_Parameter["mailBody"]);
$WA_MailObject = null;
}// WA_SecurityAssist_Email_1_SendMail
if(isset($_POST["Send_x"])){
//WA SecurityAssist Email object="Mail for Linux"
$WA_Auth_Parameter = array(
"connection" => $connSAMPLE1,
"database" => $database_connSAMPLE1,
"tableName" => "Equipment",
"filterColumn" => "Email_Address",
"columnValue" => "".((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") ."",
"columnType" => "text",
"usernameColumn" => "Member_ID",
"passwordColumn" => "userP",
"selectColumns" => array(""),
"sessionVariables" => array(""),
"successRedirect" => "SAMPLE_LogIn.php",
"failRedirect" => "SAMPLE_EmailPW.php",
"keepQueryString" => TRUE,
"toAddressColumn" => "Email_Address",
"fromAddress" => "SAMPLE@testcase.org",
"fromAddressDisplay" => "SAMPLE Association ",
"subject" => "SAMPLE Password Request",
"mailBody" => "User name: [Member_ID]\nPassword: [userP]",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
AND HERE IS THE REVISED EMAIL PASSWORD REQUEST FORM:
<div id="ForgotPWContainer" class="WAATK">
<form action="SAMPLE_EmailPW.php" method="post" name="WAATKForgotPWForm" id="WAATKForgotPWForm">
<h1>&nbsp;</h1>
<table class="WAATKDataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th>Email:</th>
<td><input type="text" name="emailAddress" /></td>
</tr>
<tr>
<th>First Name:</th>
<td><input type="text" name="First_Name" id="First_Name" /></td>
</tr>
<tr>
<th height="32">Last Name:</th>
<td><input type="text" name="Last_Name" id="Last_Name" /></td>
</tr>
</table>
<div class="WAATKButtonRow">
<p>
<input type="image" hspace="0" vspace="0" border="0" name="Send" id="Send" value="Send" alt="Send" src="../WA_SecurityAssist/images/Slate/Refined_send.gif" />
No, the security assist email does not support looking up an account by more than one column.
In the case where you are allowing for users to register with the same email address, your login should use a unique username instead of the email address. The email password page can them use the user name to look up the account.
stuff269776
Thanks for letting me know. If SecurityAssist (and Dynamic Suite overall) can't handle additional fields in the query used for a "Forgot Password" page then I'll need to create a "Forgot Password" page from scratch.
For this website, each registered member is indeed assigned a unique member ID that is used for login - but if they've forgotten the password then they've probably forgotten the numeric ID so it's not much help on the "Forgot Password" page. I'm working with an existing membership with hundreds of registered members so I can't reasonably ask my client to change their existing set-up.
Thank you for the info.
J.
Yes, you will need to create the forgot password manually in this case.
