Known issue (and solution) with deprecated split() function
Thread begun 8/17/2009 3:50 pm by Anna Robinson | Last modified 4/25/2011 11:39 am by Jason Byrnes | 6129 views | 3 replies |
Anna Robinson
As discussed in previous threads, the split() Function was deprecated in PHP 5.3. This function is used by Validation Toolkit server behaviors. Replacing the WAVT_Scripts_PHP.php in your installation of Validation Toolkit provides the run-time code necessary to correct this issue.
To get the fix, go to the Download Center of our website. Log in and visit downloadcenter.php. Click on Validation Toolkit (or the suite you owns that contains it); then click on the Known Issues section. Download the zip file and follow the instructions in the readme file.
toms016390756
Thanks!
walt125013
Please help with the split() Function was deprecated in PHP 5.3
I cannot find the solution for this anywhere. There is no Known issue file that i can find. Where would I get this....Please help.
the manual solution is to open the WAVT_Scripts_PHP.php file and find all instances of "split(" and replace it with "explode("
