Database Connection problems
Thread begun 8/14/2009 11:20 am by bernardkane381926 | Last modified 9/02/2009 2:42 am by bernardkane381926 | 4614 views | 5 replies |
bernardkane381926
Sorry but I thought I had go this cracked but clearly not. When I try to access the user registration page I get the message - No database selected. My localhost.php code is
# FileName="localhost.php"
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "localhost";
$database_localhost = "bksol_adminbks";
$username_localhost = "bksol_beeky";
$password_localhost = "rara09winks63";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
mysql_select_db("bksol_adminbks");
Where I have added a new user name "bksol_beeky" and a password "rara09winks63". I am really frustrated over tis can you help please before I decide to go and join a bowls club!!
the error suggests that there is no database named "bksol_adminbks" on the MySQL server.
bernardkane381926
Database Connection Problem
Sorry but there is a database called bksol_adminbks and user is bksol_beeky. I am looking at both these in the cpanel url index.html see attached jpegs. I have also included a dump of the phpmyadmin page which clearly shows the database and your users table.
Also now when I try to access the users_registration.php form through a link on my index page I get this message:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /data03/bksol/public_html/WA_Globals/WA_Globals.php:78) in /data03/bksol/public_html/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /data03/bksol/public_html/WA_Globals/WA_Globals.php:78) in /data03/bksol/public_html/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Is there anything else I can do to check or get going with the connection because I am absolutely stumped if not. Alternatively if I can send anything else that may help an answer to the problem let me know.
Beeky
I have created a tech support ticket for you so we can look into this issue.
Pleas update your ticket by logging into your support history:
michaelf0199272
I think I know the solution to this issue.
I think that your issue is with the phpMyAdmin that you are using. It is encounting a statement that it could not translate. So this cause it to give error #1044, where access is denied or did not recognize\see the database.
1) remove -- CREATE DATABASE IF NOT EXISTS <name of data base that you tried to import>; from the database.
Then save the revised copy.
2) You also need to edited Connection\localhost.php to reflect the actual database.
This is what you have -- it looks correct to me.
# Type="MYSQL"
# HTTP="true"
All that you need is to do step 1 of my suggestion and you should be fine.
I hope that this helps.
bernardkane381926
Fine now thanks.
