Display search results in Table - Repeat Region & Repeat Selection
Thread began 8/13/2009 3:26 pm by mywebassist220499 | Last modified 8/21/2009 9:07 pm by mywebassist220499 | 1992 views | 20 replies |
mywebassist220499
I've used the DA search wizard to construct a search. I want to show 20 records per page in a table with 4 columns and 5 rows on the results page.
What is the proper sequence for apply the Repeat Region and the Repeat Selection server behaviors and to what elements should they be applied?
Which is applied first and to what element? The record results, the td or the tr.
What element is the 2nd applied to?
David
Use the Repeating Table Server behavior, it will apply the repeat region and repeat selection tools in the correct order for.
Once you have applied the Repeating Table behavior, it will one table cell to the page, you will need to configure inside that cell how the data should be displayed.
mywebassist220499
Hello Jason and thanks for replying.
I want to make sure that I am following you correctly:
1. Add the Repeating Table Server behvior to the page, specifying the columns and rows.
2. Place inside of the one cell, the information that is to be displayed for each record, just the information, not any other "repeat" behaviors.
David
mywebassist220499
No, what I described does not work:
From the WA toolbar click the Data Assist Repeating Table behavior.
Specify the recordset.
Specify the Rows (5) and Columns (4)
Leave Alternative content: set to <td>&nbsp;</td>
Click OK
Paste the desired recordset data row(s), for example:
<?php echo $row_rsImg['imgNum']; ?>
into the first (left) cell.
This only shows one <tr> of 4 records from the 38 found records.
What am I missing?
Sounds like it was done correctly, please compress a copy of your file in a zip archive and attach it tto your eplay so I can take a look at the code.
mywebassist220499
Ray,
Is posting code in the public forums now the only way to have Web Assist Tech Support take a look at it?
mywebassist220499
Asking again. Is there an option for uploading code for Web Assist Tech Support to look at without posting it in a public forum?
mywebassist220499
I'm requesting a support incident on this.
Would you please open a support incident on this and I need to get it resolved and do not wish to post my pages in a public forum. Last response from WA on this was on 8/14
I apologize for the delay, I have been a little backed up.
I have created a ticket for this matter, please update the ticket by logging into your support history at:
mywebassist220499
Hi Jason,
Suggest more fruits & vegies. :-)
I will assemble the files and post the the ticket.
