Manual processing of order using eCart
Thread begun 8/12/2009 9:12 am by dmtompki336862 | Last modified 8/14/2009 9:45 am by Jason Byrnes | 2988 views | 3 replies |
dmtompki336862
I'd like to create a eCart site where I receive the completed order information manually via email or database, and process the transaction after a full review of the order (the orders are for a service not a product). Can I do this using my Ecart software and what additional information will I need to know, or where should I look for help/documentation with this?
The simplest way to accomplish this is to Use the Checkout wizard to create the pages. When using the checkout wizard, you will have to chose a payment gateway. Select Paypal Payments Pro US as the payment gateway. After the pages have been created, remove the PayPal Express Checkout button from the Checkout page, and remove the local Checkout server behavior from the Confirm page.
You will also have to reset the redirect to the success page. If you selected to have the order Information stored in the database, double click the Store order Details server behavior and set the redirect. If not double click the Universal Email server behavior and set the redirect to the success page.
NOTE:
You should not store Credit Card information in your database, or send it through email.
dmtompki336862
Confirm/Universal email error
Your solution worked excellent, thank you.
However, I did receive this error after confirmation:
Warning: Missing argument 6 for WAUE_Definition(), called in /html/WA_Universal_Email/WAUE_confirm_1.php on line 15 and defined in /html/WA_Universal_Email/mail_PHP.php on line 69
Column 'opt1' cannot be null
This appears to be two separate error messages.
On the Confirm page, double click the Universal Email server behavior, on the General Tab, make sure that a character set has been chosen.
In either the Orders or the Order Details table you have a column named opt1 that is set to not allow nulls, It looks like the Store Order Details or store order summary behaviors are not set to give that column a value. You should modify that column to allow nulss or set a default value for it in the DB.
