Space in the home page
I need to modify (reduce) the free space, below Slide show in the home page, what tools i use the CMS or modify the template, and which parameters I modify for reduce that space????
Massimo
Massimo
Jason the link is: www.tessyacconciature.it
it looks like you have changed the gallery to use the 1024 progressive image width, this uses a 768px height for the gallery, the images you are using are smaller than that, so thay are not being resized to the full 1024 X 768 size because that would cause them to be distorted, but the view port for the gallery is still using those dimensions.
