Fatal error:Call to undefined function virtual()in/home/minutorg/public_html/index.ph
Thread begun 8/05/2009 12:01 am by Wayne366927 | Last modified 4/02/2015 11:50 am by Ray Borduin | 25287 views | 11 replies |
Wayne366927
Hello:
When I run Site Assist and upload the site I get the following error when I browse the site: "Fatal error: Call to undefined function virtual() in /home/minutorg/public_html/index.php on line 64
Line 63 in the /index.php says:
"<?php virtual("/CSSMenuWriter/cssmw_home/menu.php"); ?>"
What am I doing wrong?
Wayne G.
change:
to:
<?php require_once("CSSMenuWriter/cssmw_home/menu.php"); ?>
Dreamweaver is using the "virtual" syntax because in your Site Definition, the "Create Links Relative To:" option is set to Site. If you change that to "Document" instead, Dreamweaver will use the "require_once"syntax.
Wayne366927
Hi Jason:
Thank you for your considerate, prompt and correct answer. Your support is making the learning curve a bit easier to deal with.
Best regards,
Wayne G.
you're welcome, glad to help.
bear389523
Thank you
Same problem for me. Spent hours trying to figure it out. :(
Thanks so much!! Too easy when you know what your doing!
Mike
tiffanyginestra363654
Mine too... but also
That solved my issue as well... And the menu shows up, but it's still not showing the css for the menu. Do you have another easy fix?
Please post a link so I can take a look.
Sorry it took so long
Here is a link:
firstclasscarpentry/
your page is looking for the menu css at:
menu.css
this location gives a 404 page not found error.
make sure you have uploaded the CSSMenuWriter folder to your server.
It works!
Thanks so much!
I couldn't see that because I had it as a relative link from where the spry was being viewed.
Using your information, I replaced it as a relative link from the root folder and it worked! Awesome!
