Database DataAssis pages wizzard
Thread began 6/05/2012 10:21 am by danielsebas | Last modified 6/07/2012 9:05 am by Jason Byrnes | 1055 views | 3 replies |
danielsebas
Hi I used the Database -> DataAssist Pages wizzard to create an update page, I put validation to a field with HTML Editor the field is as required, but when I created the page it is not validated as requiered, I try to generate again the page and noticed that when I leave the validation wizzard and enter to it again the changes for the HTML Editor field are not applied.
I hand coded the page to add the spry validation, but it doesn't work as it should.
Thank you in advance.
The validation setting sticking issue should be corrected in the next update that is scheduled to release later this week, or early next.
Spry validation cannot be used for an HTML Editor field.
to add validation for HTML Editor, you need to edit the Server Validations behavior that is added to the page.
Open the server behaviors panel, and double click the Server Validations server behavior.
Select Required, not blank for the validation type, for the server variable, click the lightning bolt icon, and select the HTML Editor form element.
then click the plus button to add the validation to the list.
danielsebas
Thank you Jason, When I create a form with CSS Form Builder, the spry validation for HTML Editor works, though I copied the code from that form to the page made with the update wizzard it didn't work . I've tried to use that form to update the records, but the update behavior doesn't work or I'm not using it properly
