I need to change the Dataset label location and/or style?
Thread begun 7/31/2009 11:16 am by tom92909 | Last modified 8/04/2009 8:56 pm by tom92909 | 6903 views | 10 replies |
tom92909Beta Tester
I'm using Dynamic Web Charts in an dynamic XML configuration.
The chart is working correctly and I have just a few more requirements to get the exact output I need...
1. I need to have full or better control over the Dataset Label. I'd like to place it in where ever I want to or dynamically call it outside the actual chart perhaps and remove it from it's upper left hand corner default location inside the Flash area.
<dataset style="{color:#767a7f;font-size:14px;}" size="14"
width="2" color="#0000CC" dotsize="4" opacity="80"
abstraction="4" outline="#5a6484" linecolor="#5a6484"
type="line" subtype="dot" label="My Data">
2. Dynamic Hyperlinks off of chart points. How is that accomplished exactly?
Is it as simple as this?
<point>
<value><a href="my_link_location.php"><?php echo $row_getData['field1']; ?></a></value>
<label>DataPoint1</label>
</point>
Outstanding product by the way. :D
tom92909Beta Tester
I found the XML tag for the hyperlinks.
<pointlink></pointlink>
So I managed to answer my 2nd question.
I still need to find out about the 1st question related to controlling the Dataset labels.
Thanks!
tom92909Beta Tester
Good Monday morning. Just checking on an update to my original question.
Originally Said By: tom92909
Hi Tom,
I am unaware of any way you can manually position the Dataset labels. There is no setting to move the dataset label and applying CSS will not affect the position.
I apologize for this limitation on the product.
tom92909Beta Tester
Jimmy,
Thank you for your reply.
Ok with that limitation identified, can I not display the Dataset Label at all?
Can I disable the Dataset Label completely?
If you go into your <pagename>_data<num>.<serverType> file located in DynamicWebCharts->Data folder of your site, you can remove the label="<datasetLabel>" part underdataset which will remove the label.
So in your specific example if you deleted the last part of the line (label="My Data") the dataset label will not show up.
tom92909Beta Tester
Jimmy,
Yes, that does work, but when the <dataset label=""> is removed, it also chops off the top half of the Y-Axis label tick for the upper range number. How can I avoid this?
I am one step away from perfection! I just need to resolve this last display issue.
Just for visual reference...
I hope this helps you better understand my problem.
tom92909Beta Tester
Just need one last update to resolve my last issue. I hope to hear from you before the end of business today.
Thanks! :)
tom92909Beta Tester
Just checking back in for an answer.
I'm not sure what's causing this. My axis labels do not get cut off when I remove the dataset label. Can you show me a page uploaded to a server so I can take a look at it?
