Framework Builder Select Plugin Issue
Thread began 5/21/2012 1:45 pm by Jordan | Last modified 5/21/2012 3:32 pm by Jason Byrnes | 232 views | 1 replies |
Jordan
I am using CS6 with Mac OSX.6. Whenever I try to add a plugin and use the directory select button, the window appears to select the plugin but it won't close. I then need to force quit Dreamweaver to carry on working.
I have a similar issue with with Image Resizer where there is an error when you select the directory button.
This is caused by a bug in Dreamweaver CS6 on Mac OS that we have identified.
we are working to correct the problem and will be releasing an update late this week ,or early next week to address it.
